5. 8 GHZ 17 DB HG AAT
5.8 GHz 17dB High Gain AAT Automatic Antenna Tracker for HD FPV RC Racing Drone
Product Description:
Model: 5.8 GHz 17dB AAT Automatic Antenna Tracker
Frequency Range: 5150-5950mhz
Input impedance: 50Ω
VSWR at surface level: <1.5
Antenna Gain: 17dBi
HPBW (3dB): 16 ° H-plane 38 ° E-plane
F/B:> 20 (dB)
Max Power: 50W
Polarization: Vertical polarization
Connector Type: RP-SMA
Static protection: DC ground
Antenna Length (AAT): 30 cm
Weight: 57g (Manual)/47g (AAT)
Package included
1x5. 8 GHz 17 dB high gain
,,, and Dr. Pepper says....
When the PDF is a scientific article I have perhaps access
Edit: here it is:
wong2004.pdf
Dimensions; vibrator = 129x129 mm; reflector = 168x168 mm
I was always interested in how such antennas are feeding. Is the outer braid of the coax soldered onto the reflector?
,, not really, it is welded on the back of the double plated circuit...!!!
Hello, is there a detailed drawing \ of that antenna?
can you give to us the all te dimensions of the antenna?
I don't have the file but in the future I will be able to give you the dimensions.
