Antena Air Live WAI-102PA (v2)
61 posts in this topic
3 hours ago, bejonet said:
my mistake have  look at the picture,  nut not to  the center vibrator and director
,,,good, I do not think this problem influences too much....!!!
,,,what displacement has the nut...???
On 9/26/2018 at 0:34 PM, Admin said:
i thinking if measurement 30mm from director and vibrator not from reflector :D  and i use reflector size is 80x100mm
,,,these are the dimensions ... !!!
the length of the director and vibrator is 56mm, while the nut distance from the long side is 30mm, so the nut is not in the center ?? that's what I meant
I tried using a comparison of tplink wr-741nd with default  omni and this antenna, the result is still better using omni
" be careful ... vibrator size = 53mmx56mm
                     directory size = 48mmx60mm
I thought the length of the director and vibrator were the same, meaning the director was longer than the vibrator right? :D  thanks brother..
another question ..
what about models like this, for the 2400mhz sectoral antenna, is it possible?
,,, you can not, how as crossing the adaptation line, the potential null point ... ??? !!!
,,,or something of that kind...
thanks for correction  and yes it work, this patch more signal strength than my omni antenna 10db..
is it possible?
,,,,good, and yet it seems to be broadband...!!!
,,,and the required dimensions...
What, is it hard to cut a sheet of wire ... ???
i mean this, whether using wire or cooper plate? because it is hard to cut cooper plate that size
Okay,then try a cooper wire 1....1,2mm or 1,6mm,it must to do a simulation...!!!
After several simulations, I have reached a diameter of 0.8mm copper wire...
good...
thank you Admin, i was have to made it, next i will try to changed with copper wire..
On 9/26/2018 at 2:31 PM, Admin said:
is it possible to make mimo with size of reflector is 100mm x 160mm
"No, because it does not have a good isolation between the ports...!!!
have you anothers mimo patch antena idea for that reflector size ?? for wifi 2,400mhz
If you have the pleasure, why not look on this forum ??? ..
