Dual Band WIFI Antenna
Main technical specifications
1. Frequency Range: 2400MHz 5G 5800mhz
2.VSWR:<= 1,5
3. Gain: 10 dBi (max.)
4. Vertical polarization
5. Maxlmum Input Power: 50W
6. Connector Type: RP-SMA plug/SMA plug
7. Length: 19.5 cm
8. It is widely used for wireless transmitter and wireless receiver. Such as AP, WLAN ,WIFI router, WIFI adapter.
9. Advantage: Nickel-plated has excellent quality in solubility, conductivity and stability in metal.
10. It has two colors, you choose black or white. Thanks.
...yes, but I don't really trust the gain of the antenna..!!!
Marketing technik as usual
sir, in our page wifi omni antenna is rare to find, can you fetch and share it with some dwg.files, please sir. thanks in advance.
