alsamman80
4G Antenna
Hi,
I want to boost two bands B1 and B3. Can I make two antennas 1200 Mhz and 2100 Mhz and connect them one to the Main and other to DIV of my router?
If I want to boost only the 1800Mhz band (B3), is the better to make two separate antennas or to make one antenna with two cables?
Any wide range antenna 1800-2700 for 75 Ohm cable?
Thank you so much
