DC13th
Copy Of Antenna Mimo 16dbi - 120° China Product
86 posts in this topic
,,,wow  dude, where did you get that, you got the original?
yes i copy it from original antenna
the space between the vibrator to the reflector is 2mm (if it made from the PCB just attach it).
then the distance between the vibrator to the director is 2.5mm (gap)
,,, what is the PCB thickness .. ???
,,, you can give me the antenna in one of these formats, to be able to transform it into cst *
,,,*cdr ,and *dxf don"t work in cst simulator...!!!!
PCB thickness is 1,5mm reflector thickness is 2mm
ok try this file
5Ghz 16dbi.stl
Copy 5Ghz 120.dwg
Copy 5Ghz 120.obj
Edited by DC13th
size of Director 340,0 x 20,0 mm
and Vibrator is 370,0 x 45,0 mm
(Dimension all of it)
,,,, if you have the cst file why do not you do a simulation with the program...!!???
,,,thanks dude,good, but you can extract to me from *cst file, *sat file or *igs file ,only for metallic copper part...???
i dont know to use it, its new for me
u mean like this
Copy 5,8Ghz 16dbi.cst
good, but how did you configure this on cst...??
from corel i export to *dxf file format
and i import it to CST
in CST i dot know to remove un use component or select componet
I was almost sure of this, but it can not be in that way...~!!!
,,,only this copper part has to appear...
,,, hey buddy, why do not you try to study this post...???
OK i will
