Alonso
VLF Antenna in HFSS
,,,you show how the antenna should be and for what frequencies??!!
23 hours ago, Alonso said:
Hello friends, somebody knows how to simulate an N wire loop antenna in HFSS?
I'm trying to make a VLF antenna for frequencies 10 kHz - 30 kHz, attached the model below. I'm a beginner in this area but I guess that maybe it will need 100 turns or something like that. If someone could help me, thanks a lot. (Sorry for my english btw)
Sorry, I'm a beginner in this. I've already attached what you said.
Loop antenna (antena de Lazo) should be straight away design in CST...
Lots of WIRE wounds and a Port at the ends...
10-30khz...i'll give it a TRY in CST LOTS of wire for that LOW...
Alonso para que uso la vas a usar...(What use you're planning for this...?)
https://stormwise.com/page28-VLF.htm
Thanks. Estoy planeando captar señales de la ionósfera (I'm planning to capture signals from the ionosphere).
12.3 inch long x 1.02 inch diameter ferrite rod core for maximum reception
31 cms x 2.6 cms
OLD AM radio variable cap
i'll try in the next days and post if GOOD..,.
