Triple frequency+dual frequency LPDA SDR 0.3 to 6ghz
Still testing , Imepdance needs some work still...But looks good so far)
Copper tape under 40 cm long and wide...PES foam or PU foam dielectric
Make some modifications, distance parallelism has been CURVED to allow for a soft Impidance curve...
6-7 dbi gain from 300 Mhz to 6000 mhz
best response is between 1 ghz and 4 ghz...
looks good to me
SDR is the intended use...
Clanon, how do you make this practical antenna, isn't it a bit complicated...???
YES it is complicated...but the results are REALLY GOOD
The Vivaldis have NO GAIN...(THIS have 7dbi or more over the WHOLE BAND)
Thinking in cutting copper tape by hand ... after printing the dwg dxf 1:1 blueprints...
CAN NOT be made in PCB board (distance between HALFs are changing gradually from back to balun)
making it on pcb board would get you HUGE variations on Impedance over the whole band...
52 minutes ago, jbckdsav said:
Vivaldi have no gain? Please.
Who told you this? xD
under 1000 mhz that is...3 4 dbi
They get gain over 1ghz
https://antennatestlab.com/antenna-examples/example-3-vivaldi-antennas-rfspace
this is the MOST EXPENSIVE vivaldi out there...and it SUCKS under 1000MHZ...
I was tryin to change that...did my research...Build some antennas after MONTHS of simulations...still do...
LPDA is the BEST for uwb with a DIRECTIVITY (7 dbi without reflector 12-15 with reflector) CAN't beat that
BUT it's hard to build...
over 100 us$ FOR NOTHING...fucktards buy stuff for their LOOKS! lmaoCaptura.PNG
Where did you get this from?
almost NO GAIN
