Magnita-1 - universal car antenna 4G/3G/2G/WiFi
This antenna is designed for use on mobile and stationary objects. Antenna works with any devices in the range of 790÷960/1700÷2700 MHz (USB modems, repeaters, amplifiers, etc.). Thanks to a wide band antenna capable of operating in the most skorostnyh the mobile communication standards, with a maximum Internet speed up to 300 MB/s For the implementation of the MIMO mode, it is recommended to use two such antennas. Light weight, great aerodynamic shape and use of rare earth magnets in the magnetic system allow to keep the antenna on the roof of the car at speeds above 150 km/h!
The electrical characteristics of the antenna Magnita-1
Operating frequency range, MHz 790-960/1700÷2700
Gain (excluding cable loss, when placing the antenna on the roof of the car), dBi 2÷4 / 6.0÷7.0
Gain (excluding cable loss, when placing the antenna in free space), dBi Of 2.0÷3.0
The width of the days in H-plane, degrees 360
Days width in E-plane 3dB hail 15÷45
The elevation angle of the main maximum of the radiation pattern when placing the antenna on the car roof, C 5÷25
Input impedance, Ohm 50
SWR in the frequency range, not more 1,6
Permissible power watts 10
Polarization vertical
The mechanical characteristics of the antenna Magnita-1
Weight with cable g 240
Dimensions without cable, m 0,10 x 0,10 x 0,08
The force of attraction of the magnetic system (when the thickness of the metal roof of the car - 0.7 mm), N 50÷55
Connector SMA-male / on-demand
The material of the radiator tin tin
Material samango casing
ABS + polycarbonate
Jomy do you have an stl file i'm interested on check it...?
THIS I SEE might be YOUR main problem...(Cut again to eliminate the bridging between CONES , it should be open and the disc is plastic)
I don't think so, anyway the base cone is electrically connected to the reflector.
BI CONE , central  feed wide band (base is dielectric)
I think the base is magnetic for attaching to the hood of the car...!!!
Yeah , that figures...it should have some impact on Simulation (as Ferrite FeO2)
