antenna_kid
Antenna with gain over 10dbi for 868Mhz and 750Mhz
35 posts in this topic
On 19.03.2024 at 0:35 PM, Admin said:
yes, but its still for 75 ohm. need 50 ohm version.
,,,antenna_kid, maybe you would be interested in something like this...
Hi, excelent :)thank you.
thickness of elements is the same (2mm) ?
Can it be 1.6mm. Asking because have double sided FR4 laminate. It will be easier to make them (cut on CNC).
Do you have also such design for 868 Mhz ?
Will try make them both.
,,,the thickness of the material does not matter...!!!
I think that in order to cover both frequencies(750 MHz;868 MHz), a single Batwing antenna should be used.
any dimensions for that bat wing ? You have right - 1.4 is not bad at 750 :) What impedace does it has at 868 and 750 ?
GOt question, this tube diameter is critical. Asking beczuse will be quite hard to find 30mm brass tube. Brass rod is quite expensive for that diameter.
Edited by antenna_kid
 ,,,this tube diameter is not critical(20-30mm)...!!
I will also give the dimensions of the Batwing antenna.
I still tried to make a simulation with this type of antenna, but it is not so promising,,,
I think the directory should be made with concentric copper circles.
