acri
antenna 27TNJ SISO BSM13
This antenna it"s really good but , I  will make my  own product with the simulation results in CST
Now I hawe 5,8 SiSo 13gBi and wil develope it into MiMo,everything needs a long process
please support,because my equipment is verry limited
this SiSo 5,8GHz 13dBi with coaxial Teflon RG174
this finally for CPE modif
CPE mod from my friend with radio bulletm5
test results in the air
result on simulation
...wow, can you give some size ... ???
ok, but tell me though, why only 13 dBi ...?
can You show how to solder coaxial cable to the patch antenna and  CPE mod
ok, I'll give the size later
because it was the result of the simulation in CST, with such results I was very grateful
i dont know, this picture from my buyer
Can you give the sizes or design? I have find a similar patch panel project in web, i think it could be more or less similar.
Panel 16dBi 5GHz – jednostronny - 56mm x 57mm - distancia refletor 4 a 6mm.jpg
not same,  according to admin my design is not good
still the better model that you give the picture
 Thank you for answering. I don't speak English natively, so I don't know if I understand it very well. You said the design I showed you was better?
Well, but the antenna has nothing to gain in the directivity 16dBi , as they say...!!!!
,,,,patatua666, where you found this drawing...???
Panel 16dBi 5GHz 56x57mm
2 hours ago, mbahbar said:
please give me detail in cdr format
I'm sorry, I don't have this drawing in the original, I made an approximate measurement...!!!
,,, ask "acri" where he found this drawing ... !!!
