acri
STUCK on CST
39 posts in this topic
after I unistall and I install again ... it turns out the problem is still the same
,,,have you uninstalled it with REVO ... ??
,,,after uninstallation, shut down and restart the computer...!!!!
2 hours ago, Admin said:
,,,one more time...!!!
after all I tried ...
apparently the results are still the same :D
I might be crazy ... hahehehehe
you are driving me crazy ...!!!
my cst file is going to you?
brother, the file that you gave me, can I open it and I can see the results ...
but when I delete the results and I try to repeat the process it turns out the process stops exactly the way I posted ... even though I reinstalled CST by restarting the pc it turns out the results are the same as the process stopped
which makes me wonder, if the usual model for example 1 patch the process runs smoothly
Edited by acri
solved brother i change CST 2014 with CST 2018
thank for help me
ok, you have now the latest version of cst on an old computer ...!!!
hehehhe
thank you very much for the time you give
The version is not important, the computer is not important. To solve the problem, you need to change the type of solver - voila. Sorry for reviving the zombie post.
7 hours ago, clanon said:
learn that...(the hard way)¬¬
In fact, Demiurge is partly right. The version of the computer is not that important. You don't even have to change the solver. I have been using this toy for more than half a year. https://aliexpress.ru/item/1005003481605422.html?_randl_currency=RUB&_randl_shipto=RU&acnt=4173237791&aff_platform=jvru&aff_short_key=brxT3bLh&albad=539506445161&albag=126913380958&albagn=pc&albch=dspl&albcp=14307178457&albkwd=pla-385021937959&campaignName=JVRU_PC_ALI_WEBall_RF_UA_sTrade_ROAS_AFFCAll_New_MCC_Perform&cn=14307178457&dp=EAIaIQobChMIquLJ6JeM9AIVEBd7Ch1Q1Q4MEAQYAyABEgLVFPD_BwE&feed_id=20&gclid=EAIaIQobChMIquLJ6JeM9AIVEBd7Ch1Q1Q4MEAQYAyABEgLVFPD_BwE&isdl= y & netw = u & sellermenu_hide = true & sku_id = 12000025982654071 & src = googleweb & tracelog = googleweb_jvru_pc_14307178457 & utm_campaign = JVRU_PC_ALI_WEBall_RF_UA_sTrade_Allmed_Acc At about $ 150, it can handle most CST2021 projects. Of course, the computing speed is slightly worse than that of the Ryzen5 3600, but it is quite workable. There are practically no differences from the speed of the CST16.
