acri
inside Sectoral 5Ghz MIMO RB921GS-5HPacD-15S (mANTBox-15s)
review inside RB921GS-5HPacD-15S (mANTBox-15s) 15dbi 120 degree from my friend
Edited by acri
mantBox Antennas
1 hour ago, Admin said:
,,,yes,mantBox Antennas...
its real 120 dbi :D
how to create antena model mantbox 15s
it"s real 120 dbi...????????????????????/
,,,maybe 120 degrees...!!!
mantbox 15s is 15dbi mimo dual polarization 120 degree
well, we see there are two separate antennas but dual polarization ...
1. The question is whether the 2 antennas are arranged in series or arranged in parallel?
2. the second question, can 1 mimo model router be installed with the same antenna model as the mantbox?
I think that this mantbox 15s antenna is arranged in parallel
because it can be seen from the video that there are 16 patches ... 8 on the right and 8 on the left, so that the resulting angle is greater
what do you think of my brother?
,,,if you have this device, why not dissect it, to see exactly ...???
I don't have this device because it's very expensive ... :D
the device I have is only an indoor router that I modified into an outdoor router
7 hours ago, Admin said:
,,, the antenna inside looks so...???
maybe yes, maybe no .....because the design has a design from a VJJT antenna from chinese
i think VJJT is copied from mantbox, but different  dimension and size
acri don't worry mantbox is more than 120degree in the real beam, but vendor says 120degree
this is Mant reflektor
try to create a scheme for mantboxs 15s in cdr format
