KROKS KAA10-1700/4200 4G / 5G MIMO 4x4 10dB U-BOX Panel Antenna
KROKS KAA10-1700/4200 is a broadband (multi-band), directional MIMO 4x4 panel antenna with a gain of 9-11 dB.
The antenna supports LTE advanced technology and is designed to work with LTE / 5G modems Cat. 6, Cat. 9, Cat. 12, Cat. 16, Cat. 18, 5G (N78) with the possibility of frequency aggregation, as well as routers with a built-in modem operating in the frequency range 1700-4200 MHz.
Dimensions (length, width, height), mm 250 x 250 x 100
Dimensions, weight, quantity of goods in a package:
Individual package dimensions (length, width, height), mm 255 x 255 x 110
Weight in individual packaging, grams 1400
Number of products in a group package, pcs 12
Antennas-characteristics :
Operating frequency range, MHz 1700-4200
Antenna gain, dB 9-11
SWR in the operating frequency range, max. 1.6
Polarisation Linear
Wave resistance, Ohms 50
Maximum input power, W 10
Connector SMA-female
Permissible wind load, m / s 30
Operating temperature range, oC -50 ... +90
Maximum permissible air humidity, % 100
Port decoupling at least, dB 30
Communication Standard
5G
LTE 2600
UMTS 2100
2.4 GHz WiFi
LTE 1800
Multi-band
Mounting type -on the pipe
Execution type Panel version
With a hermobox
MIMO Support
MIMO 4x4
