PETRA-9 MIMO 4x4
Professional panel antenna for modems and routers that support MIMO 4x4 technology. F=1700-4200MHz, CU=9dBi, 4 x N-female connectors, vertical+horizontal polarization, decoupling between channels of more than 25dB.
Electrical characteristics of the PETRA-9 MIMO 4x4 antenna
Operating frequency range, MHz 1700÷2700
Gain factor, dBi 8,5÷10
Bottom width in the H-plane, deg 59÷82
Bottom width in the E-plane, deg 35÷57
Side lobe level, max -7 dB
Decoupling between ports in the operating range, not less than 25 dB
Input impedance, Ohms 50
SWR in the operating frequency range at the inputs, max. 1,6
Permissible power, W 10
Slope of polarization of received / emitted waves -45°/+45°(X-pol)
Antenna weight, g 820
Bracing mast diameter 20-52mm
Operating temperature range -60°C to +80°C
Overall dimensions without mounting, m 0, 24x0, 24x0, 1
Permissible wind speed, m / sec 25
Connectors 4 x N-fe male
Material of the protective cover Polycarbonate
Antenna Material Galvanized steel, brass
Mounting material steel / Polycarbonate+ABS
I tried to make a simulation but I think there is still work to be done on it...
15 hours ago, fjaxo said:
This antenna max 1700-2700.
,,, the frequency of 4.5 GHz is not visible...???
,,,why this difference in the location of the ports...???
post cst
"I don't think I have this file anymore...!!!
Maybe only if I bring this topic up again.
Jomy , These BALUN details might be IMPORTANT to know (3-4 feeding STRIPS) do you have a drawing with Dimensions...(Russians use it all the  time)
Clanon, can you show me this details...
I was hoping YOU have the drawings...i never draw any of those antennas...Is on the Petras and others a 3 strip balun from reflector to antenna...
17 hours ago, clanon said:
maybe something like this
I don't understand anything anymore, I'm in a different location and I can't see some previous posts and some pictures ...like this....
is a link to your OWN site...
