bejonet
biquad antenna digital TV
93 posts in this topic
,,,,and generally, this antenna is better .... ??
Приветствую тебя! Да, антенна super! В городе показала себя на 100% . За городом не испытывал, но думаю нужно будет ставить малошумный усилитель. в любом случае - благодарю.Если появиться что-то интересное, пиши, сделаем!
Greetings! Yes, the antenna is super! The city has shown itself to be 100%. Outside the city did not feel, but I think it will be necessary to put a low-noise amplifier. in any case - thank you. If there is something interesting, write, we will do it!
,,,yes, very good, but be careful that the coaxial cable must pass through the back of the reflector...!!1
Приветствую тебя.При установке на мачту сделаю как надо. То,что на фото, пробный вариант,чтобы показать работу.Как твои дела, как настроение?! У нас начались майские праздники - длинные выходные!!!!
I welcome you. When installed on the mast, I will do it right. What is in the photo, a trial version to show the work. How are you doing, how is your mood ?! We started the May holidays - long weekend !!!!
,,,well, thank you...!!!
,,,,yes, we have been the holy pastas, now they have passed...!!!!
i'd like to build this antenna for TV channel  UHF 25 (500 - 550 mhz)...if some one has PDF  scale 1:1 file for biquad antenna would be greAt....
tnx a lot admin...
Привет. Свяжись с админом .Он поможет с расчётами.удачи.
Hey. Contact the admin. He will help with the calculations. Good luck.
,,,for tcl32...dimensions in red...
many thanks admin....i will build soon ..after find I the software to print it such drawing...
,,,,ooohh  TCL32 ,,,, stop, stop, stop ... it looks like the dimensions that I gave you before are not good ,,,, expect to do a simulation....!SORRY!  OKAY....??/
Yes, I think this is the best one...
its..Okay Admin......tnx a lot for correction....i have draw the biquad in COREL DRAW....
1.  admin...i just realize that the bandwith is narrow compared to the first design that bejonet build..
2. how long the distance between supporting bolt ??
3. plan to build the antenna with 0.3mm galvanized sheet...
Well, then make Bejonet's antenna...!!!
,,, or maybe it"s better something like that ... !!!
,,,but there is not a biquad antenna...!!!
,,,UWB digital TV...!!!
,,,you want it...???
I have adopted a new line of adaptation,,,,
i finally build this UHF TV antenna...
perform quite good....design based on rothamnel antenna book....
,,, good, put the dimensions if you can ... !!!
