Petra-12 MIMO 4x4 Unibox-2
Universal panel antenna 9-12dBi (1.7-2.7 GHz) for modems with support for MIMO 4x4 technology + hermobox for modem
Electrical characteristics of the PETRA-12 MIMO 4x4 Unibox-2 antenna
Operating frequency range, MHz 1700-2700
Gain factor, dBi 9÷12
Bottom width in the H-plane, deg 28÷45
Bottom width in the E-plane, deg 55÷89
Forward / backward ratio, dB 15÷25
Decoupling between ports, at least 18 dB
Input impedance, Ohms 50
SWR in the operating frequency range at the inputs, max. 1,7
Permissible power, W 10
Polarization of received / emitted waves vertical + horizontal
Antenna weight with extension cable, g
Bracing mast with a diameter of 20-52 mm (depending on the diameter of the worm clamp)
Operating temperature range -40°C to +80°C
Overall dimensions, m 0, 24x0, 24x0, 1
Permissible wind speed, m / sec 25
Connectors 4 x SMA-male
Material of the protective cover Polycarbonate
Antenna Material Galvanized steel
Mounting material steel / Polycarbonate+ABS
Protection class IP 67
,,,after a simple experiment it seems that the results are quite good...!!!!
