AmateurRadist
2.4 & 5.8 GHz WIFI antenna can be devided?
30 posts in this topic
Hi!
I had 2.4Ghz & 5-5.8GHz 14dbi panel antenna, I'm wondering if i want to have signle band antenna like only for 2.4Ghz and only 5.8GHz antenna - can i cut somewhere in middle and still have good vswr? Antenna made of galvanized steel, here is the drawings of it?
I tried to cut right next to the soldering pin and assembled antenna but vswr was around 1.8-2.2 while factory vswr is 1.3-1.5
any help is appreciated
thanks
Hello, it would be good if you could post some dimensions for this dual band antenna...!!!!
It would be easier for me if you put some dimensions...!!!
have you seen dxf it's correct dimensions
,, you can put the dimensions on the dxf drawing..!!
I tried both options vswr still high, i placed feed1 a bit higher, to upper square though, it was originally designed with N type connector but i replaced it with cable, should it effect? i will try check sizes and send
Edited by AmateurRadist
I can help you if you don't give me the dimensions,..!!
Most interesting part is that original factory antenna's vswr showing sometimes good vswr, sometimes bad depending on analyzer-antenna cable jumper's position, like if i bend it's good, i'm using jdsu celladvisor
okay i will get dimensions asap
,,,your antenna doesn't really give good results...
Vswr is good why you think it is not good?
I cut right next to solder pin and it showed good results like peak 1.8 at 2.3-2.5ghz with a good cable, but 5.8 didn't work yet
I have at top corners, small square, can you help with that and check on simulation software?
,,,you have the possibility of laser cutting...???
5 hours ago, AmateurRadist said:
Vswr
Yes it become just ordinary service recently,  can you give some advices how to change lines?
After 10 failed attempts I think deviding was not good idea, so friends just use antenna as it is, hope above information will be useful to someone thanks
The final impedance resonance vswr s11 , have the WHOLE as target...imho
Think of each Patch as Resistances , since you have 4 patches for 5.8 and two patches for 2.4...(and YOU NEED to end up on 50 ohms) cutting in a half doesn't work for ALL patches...Filters add complexity (BUT adapt impedances to EACH BAND)
IMG_20241024_130555_069.thumb.jpg.58cffd3b190ad31a1d25f1335971c81a.jpg.3b1fea2c96eff71b32e20d76745c0cab.jpg
