SDR LPDA (300mhz-6Ghz)
Trying to make a "GOOD" Lpda , SCIFI VIVALDIs from RFSPACE have NO GAIN (under 1GHZ) , Chinese LPDAs have LOTS of LOSSES and mismatch...50 ohms FLAT ALL band , just a peak close to 1ghz unavoidable on this antennas...
1.5-2mm PES dielectric...RG316 low loss cable...
Clanon,could you give some dimensions?
DXF , easier...TWO and a bridge in the back...+ CST (2019)
Untitled.cst
Untitled.dxf
The one on the picture has a LOW FRECUENCY enhancement (200mhz) and a REFLECTOR PLATE some 10 cm in the back
Should I try with FR4 double sided PCB ?...(it must work but HIGHER LOSSES...maybe z would change...tho) Tomorrow i confirm it...
1.5 mm distance between sides (Feed Line)
Feed line on FR4 needs to be THINNER 5 mm or less...to get 50 ohms...
FR4 version...not so good...High losses and some mismatch , lower gain...
fr4.dxf
