Pupe
collinear stella-5
The stella-5 antenna made by Baltic operates in the 2400-2480 MHz band. the claimed gain is 5 dB. the diagram is circular. I tried to simulate the antenna in cst, but for some reason the resonance turned out to be shifted, all the dimensions were repeated exactly. I am attaching the project, and a photo of the SWR measured on the device
Also available for sale are the more powerful Stella-8 and Stella-11 antennas with a gain of 8 dBi and 11 dBi, respectively.
Communication Standard WIFI 2400
Frequency range, MHz 2400-2480
Gain factor, dB 11
Bottom width in the horizontal plane, deg 360
Bottom width in vertical plane, deg 9
Wave resistance, Ohms 50
SWR no more than 1,5
Weight, grams 1100
Dimensions, cm 100 x 8 x 6
RF connector N-Female
Pupe, try a Strella-11 omni antenna too....!!!
I think we still need to work on this...
I think I'll get Stella 11 in a couple of weeks. But I never got the result of the Stella 5 simulation corresponding to the measurement... I'll try again next week, maybe some thoughts will come to mind
I tried to optimize your antenna for 2442 MHz .....
On 23.11.2024 at 6:54 PM, Admin said:
,,,all sizes...!!!
You can share your file on 2.4MHz frequency
Edited by dumser2
DIELECTRICS usually , radome adhesives...All add up in this case sustracts...
thinking about 15dbi or more by adding a reflector...Sectorial...
Different SOLVERS give Different Center Frequency (Frequency vs Time Solvers)
On 30.11.2024 at 8:11 PM, Admin said:
Here it...
stella5.stl
Made in a hurry but it works, it could be improved but...
Help me set it to 2.35Mhz
Edited by dumser2
USE POLYSTYRENE FOAM (STYROFOAM) Low density as a spacer ,is TRANSPARENT to RF and have NO LOSSES
Try to reproduce it, but here is my version, I have dimensions with almost the same parameters.
,,,let it be a sketch....
