eco32
Grids and parabolic antennas with feed
In Australia, they have a strong tradition of using high-gain antennas, with versions available that are rarely seen. For starters, a factory 1300Mhz grid (I made one similar) and a 3.6HGz, in addition to the 2.4GHz 5.6GHz available in Europe.
900x600 Grids:
1.3  18dBi
 2.4 GHz 24dBi
3.5 GHz 27dBi
5.6 GHz
868MHz GHz Antenna
some feeds  were explained here : "Siple Dipole"  (which is no longer a simple dipole)
It would be good if the focal length(F/D) was also shown for each antenna grid...!!!
917 x 720 welded iron bars   (Pacific Grid) 917mmx720mm and 150mm deep  f/d = 0.38
900 x 600 split die-cast magnesium f/d = TBD
600 x 400 split die-cast magnesium f/d = TBD
400 x 300 split die-cast magnesium f/d = TBD
I happen to have all sizes, i will update
additionally something from Czech republic, not in production, but still available:
Sito MMDS 175 AL http://www.satelit-tv.sk/obchod/sito-mmd...4502.xhtml Sito MMDS 175 cm kvalitne Hlinikove sito zložené z dvoch kusovParabolicke duralové sito, výška 175 cm, zisk 34dB, cena aj zo zadnym držiakom F/D = 0.41  34dBm
Edited by eco32
Update
600 x 400 split die-cast magnesium f/d = 0.35
400 x 300 split die-cast magnesium f/d = 0.38
,,,model...
grid parabola.cst
