Richard
Repurpose Di-pole for SMA connector
Hello to you;
I'm coming here in hopes of learning more about self-built wireless antennas.  So far I've watched a great number of Andrew McNeil's videos and have largely decided on this multi-element yagi
The issue for me is that I have a philosophy of avoiding money and purchases whenever possible.  I build what I need out of found items and what I have nearby.  So while I have plenty of copper house wiring (for the elements themselves), some wood and metal for a spine, and a soldering iron -- what I don't have is a metal SMA connector.  So my first question is, would it be possible to repurpose a dipole antenna piece for this?  Since there are two points which need to be soldered (like an electric outlet) there would need to be two conductive parts on the dipole.  I assume that one of the two cylinders could be that part, but I don't know if it's the one on the blue arrow or the one on the red.
It does seem possible that this piece could be used for a cantenna by isolating the cylinder from the can itself and I will likely try that with one of these.
I thank you in advance for your expertise
Aaron
Thank you very much. I did cut the piece and looked at the components.  Store-brand dipole antennas use very thin wiring (magnifying glass thin), but I'll see if it can be made to work. If not, might be nec. to buy an SMA.
"No, you do not have to buy an SMA, just unzip the plastic case from the antenna SMA...!!
