Antenna with wire elements
125 posts in this topic
,,,this is the last simulation of the zig-zag antenna...!!!
Thanks
So it is not 19 dB than maximum is 12 dB
let say little bit less than double - biquad which is 14 ,,, i think ..right?
I just cut the Cu wire but i use 2.5mm2 - ordinary electric cu wire which is
wider so maybe i get better results..who knows.
anyway antenna is easy to build...
Do you can simulate ...design i show in the image above?
if is not problem ..i don't have that CST program.
,,,okay ,I will try...!!!
1 hour ago, aurel said:
Thanks
20dBi, got with four such antennas...!!!
with the dipole side = 57mm
6 hours ago, aurel said:
What you think about this shape?
,,,why this antenna does not work ... ???
Quote
Yes why...bad design probably...:o
I don't understand this diagrams very well but i see f= 2.2  not 2.4ghz
is that mean something?
Is there any other freeware program which can replace CST maybe ?
i mean for wire antennas?
https://qsl.net/4nec2/
Auuu
that one was lame...
I found on source forge program called VEMSA3D but i don't know how to work with it?
,,, this is not an antenna simulation program ... !!!
ahhh
it is attempt to create something useful
In fact - we can create wire antenna adding nodes but is tooo slow.
I found this image ..about printed wire
sierpinski fractal
Yes, as far as I remember, I have done this fractal antenna on a forum...!!!
I found this antenna on some radio amateur site YU ..i think
and i don't get it why is connection point here where IS NOT maximum of current density?
