WIFI ANTENNA "WIFI AGENT"
DESCRIPTION
    Room of highly focused wifi antenna "WiFi AGENT" allows you to increase the reception range of a Wi-Fi signal in the desired direction, thanks to a powerful built-in antenna and built-in Wi-Fi adapter. Gives you the ability to access remote Wi-Fi household or public network at speeds up to 150 Mbps.
FEATURES
The location of the antenna:Room
Support communications standards:Wi-Fi (IEEE 802.11 b/g/n/)
Operating frequencies, MHz:2400
Gain max dBi:15
Cable length, m:1.8
Connector type:USB 2.0 type B
Built-in Wi-Fi adapter :Yes
Assembled dimensions (without mount), mm:234х190х25
Weight, max, kg:0.45
Package dimensions, mm:270х295х35
Gross weight, kg:0.6
Transfer rate, UL/DL, Mbit/s:150
Easy to install. The connection is via the supplied USB cable. If you experience problems with automatic detection of connection and "WiFi AGENT" to your PC use the supplied driver disk.
The antenna of REMO "WiFi Agent InDoor" is of the directional type. The model running in the 2.4 GHz band is able to provide you with the ability to receive even a weak Wi-Fi signal. You can use the antenna to connect to a remote wireless network. This feature can be useful when using the signal of public access networks. Using an antenna can also be useful in private homes that have a complex configuration: in these conditions, the signal from routers and access points often does not reach remote premises. The data transfer speed can reach 150 Mbit/s.
Some technical details...
The patch  connected or isolated to the to the reflecter ?  It can be used as outdoor antenna ?
,,,connected,and yes ,can be used as outdoor antenna....!!!
