List of usb wireless adapters (monitor mode)
images?q=tbn:ANd9GcSQ-aHQAQo-GccOwK8wx7D
Name and model: Alfa Network 1000mW AWUS036H
Chipset: Realtek 8187 L
monitor and reinjection mode: Yes,
Data and specifications
Remarks: The adapter No. 1 for audits, especially reinjecting in monitor mode in windows technology B / G is becoming obsolete, somewhat unstable in navigation. Possibility of using high power application alfatools accepts promiscuous mode.
  WIRELESS SECURITY RECOMMENDED for use in monitor mode.
Name and model: Alfa Network AWUS036NH
Chipset: Ralink RT3070
Notes: After the previous model, it is the second best choice for monitor mode. Has many supporters as detractors, saturated environments was somewhat unstable in navigation, supports standard N
Name and model: Alfa Network AWUS036NHA
Chipset: Atheros AR9271
Remarks: Connector for exchange or connect more gain antennas, standard IEEE 802.11b / g / n with a transmission capacity of 150 Mbps data Somewhat less powerful than the two previous models to monitor alpha mode, but more sensitive and stable her sisters to navegar.En new models have replaced the atheros chipset AR9271L.
th?id=OIP.M67951c7d550e68c66e102ddd48ac3
Name and model: WNDB-ANT Connection Dual Band
Chipset: Ralink RT2870 / RT3070
Comments: Very good adapter and monitor navigation mode, the option to use 5 Ghz makes it much more versatile than any other adapter, external antenna connector for 2.4 GHz and integrated antenna for use in 5Ghz.
Name and model: Signal King N 360000
Observations: RPSMA connector to exchange antennas different model and gain
Name and model: Startech USB300WN2X2D
Chipset: Ralink RT3572l
Comments: Very good adapter 2 connectors antena.Doble 300 mbps.Mimo2T2R band.
tp_link_adaptador_wifi_802_11n_chip_athe
Name and model: TP-LINK TL-WN722N
Observations: RPSMA connector to exchange more gain antennas of the best adaptadadores for its relacción quality / cheaper price.The with excellent results, only 100 mw will limit their power in monitor mode. To overcome the above mentioned is advisable to use with antennas direccionales.Tambien is recommended for use with an amplifier.
Name and model: ASUS USB-N14 Wireless N-300
Chipset: Ralink RT5372
Comments: Very good adapter at an unbeatable price, dual-band.
And reinjection monitor mode: If,
Notes: The option to use 5 Ghz makes it versatile. 2 external connector 5 dBi antennas to use in both frequencies, the power adapter is minimal.
Name and model: Alfa AWUS036NEH
Chipset: Ralink 3070
Observations: threaded external antenna rp-sma
Name and model: Connection WANT 15-3W
Remarks: Good adapter monitor mode, does not give the power of 3 watts advertised, high-gain omnidirectional antenna.
Name and model: Connection WANT9-2W
Observations: Connector to exchange more gain antennas incorporates omnidirectional antenna 9 dBi .No gives 2 watts of power advertised. Good performance in monitor mode.
Name and model: Wifiscan WS2024e
Observations: AIO adapter + directional antenna 14 dBi gain
Name and model: Wifiscan 2000mw / 6dbi
Observations: Aerial 6 dBi antennas RPSMA connector to exchange more profit.
Name and model: TP-LINK TL-WN727N
Remarks: internal antenna.
Name and model: Alfa Network 500mW Wireless USB Adapter AWUS050NH
Chipset: Ralink RT2770
Remarks: external antenna connector.
Name and model: Alfa Network AWUS036NHR
Chipset: Realtek RTL8188RU
Notes: RPSMA connector to exchange antennas. Audita well only medium distances. Not recommended for use in monitor mode. There is a version v2
Name and model: Érize ERZW54-USB04RS300
Remarks: external antenna connector, it supports promiscuous mode, possibility of using high power application alfatools
Name and model: Érize ERZW54-USB03H1W
Chipset: Ralink 2571 w
Name and model: kasens 2000 mw
Remarks: external antenna connector, posiblilidad alfatools application using the high power driver supports promiscuous mode.
tarjeta_wifi_54mbps_edimax_ew_7711usn.jp
Model name: Edimax EW-7711USn
Remarks: external antenna connector to exchange more gain antennas.
Adaptor-wireless-USB-54Mbps-TP-Link-TL-W
Name and model: TP-LINK tl-wn422gc
Observations: connector for exchanging different antennas profits. Good choice quality, price
images?q=tbn:ANd9GcSZc6WAyqNPUMlSwwItg3n
Name and model: TP-Link TP-WN321G v4.1
Observations: a little deaf. 100mW. without antenna, MOD.
Name and model: TP-Link TL-WN422G USB 802.11g 100mW
Chipset: Zydas zd1211rw
Remarks: supports promiscuous mode. There is another similar model but without external antenna, the TP-LINK TL-WN322G .Del TP-Link TL-WN422G-there are two versions v1 has the zydas zd1211rw chipset and Atheros AR9271 v2
Name and model TP-Link TL-WN321G
Ralink RT73 chipset
monitor and reinjection mode If,
Name and model: Érize ERZW54-USB04RS1W
Notes: works perfectly in both managed and monitor mode. I do not know if the application alfatools sevira also for erice 1w, accepts promiscuous mode.
erize_erzw54_usb04rs800_adaptador_usb_wi
Name and model: Érize ERZW54-USB04RS800 (800 mw)
Observations: I think that is the twin brother of gold 800mw externally, sensitivity is higher in the gold 800mw, supports promiscuous mode.
images?q=tbn:ANd9GcQZajbSNRlrdk0_puANbkN
Name and model: WIFLY-CITY 1500MW 20G
Observations: economic Adapter (14 €) connector sma, configurable antenna with alfatools, configurable with the driver and utility of Alfa 1w, internal heat sink.
Name and model: WIFISKY 1000 mw
Remarks: external antenna connector, high sensitivity, supports promiscuous mode, possibility of using high alfatools chipset power application
images?q=tbn:ANd9GcS_oQdN-Tn7nsmnIHcrqH-
Name and model: HIGH POWER 500mw USB LAN CARD
Remarks: external antenna connector, it supports promiscuous mode, ability to use the application alfatools high power driver
images?q=tbn:ANd9GcTAR7bkv-kghaFvcI_Im1a
Name and model: freewifilink FL2016G 1000 mw
Notes: Known as Black Dragon, external antenna connector, it supports promiscuous mode, possibility of using high alfatools power application
AWUS036ACH is a high-speed wireless adapter with support for the new 802.11ac standard.
Specifications:
Chipset: Realtek RTL8812AU
Standard wireless 802.11 a / b / g / n / ac
USB Port: 3.0 Micro-B
Security: WEP, WPA, WPA2, Cisco CCX
Compatibility: Windows XP / Vista / 7/8, MacOS X, Linux
Antenna connectors: female RSMA
Detachable 5dBi antennas
Transmission rates:
802.11a: 6,9,12,18,24,36,48,54 Mbps
802.11b 1, 2, 5.5, 11 Mbps
802.11g: 6,9,12,18,24,36,48, 54Mbps
802.11n: up to 300 Mbps
802.11ac: up to 867 Mbps
Alfa AWUS1900 is a new quad antenna 802.11ac Wi-Fi USB receiver boasting router connection speeds of up to 1900 Mbps (1300 Mbps for 5 Ghz + 600 Mbps for 2.4 Gz). It is compatible with Microsoft Windows 7, 8/8.1, and Windows 10. This connects to your computers USB port with enclosed USB 3.0 cable and boosts the Wi-Fi performance of that specific PC. This is not a router or repeater.
I'll add the cards with the 8187B , 8187L vs 8187B
Not as much signals as the version but aALL of them INJECTABLES!
·Note that 8187L displays APs with high RSSI but 8187B does not.
(APs with high RSSI are usually non injectable)
The winner is 8187B by a 15 to 20% margin."
would you recommend the best wireless adapter with high power and sensitivity  for long range coverage  and thanks in advance
what standard (speed) and frequencies ?...2.4 5.8 A B G N ...AC
2.4ghz b/g/n High sensitivity (- 96 dbm at 1mbps)  anything with AR9271 (Tplink tl-wn 722n Version 1) 150 mbps max
