alansy
lte 1800
92 posts in this topic
,,,is not a good option, you can not focus the 4 + 4 patches...!!!
,,,for which this antenna is even more ... !!!
I can do this.
I have 8 round patches for 90 mm, I can make the diameter smaller, I can solder the plates to them for powering. I can make another 90 mm, like 9 patches, I need a model of a good antenna, with dimensions and with a schedule for frequencies 1850-1765 MHz
,,,okay but wait, I'm still working on this...!!!
,,,this is for sure now...!!!
copper wire diameter= 2mm
not understood
,,,the wire diameter for the adjustment line...!!!
2 mm wire is available
Edited by alansy
Are the sizes of this antenna ready? can give? I want to do it.
,,,good, now I'm working on this antenna ....!!!
After several attempts with different antenna variants, I've come to that....MiMo Panel Antenna
But it must to  be optimized...!!!
,,,fair to poor signal...!!!
,,,for LTE...
Building-my-LTE-mimo-antenna-prototype-Bi-Quad-antenna-LTE-signal-characteristics.jpg
,,,about this antenna what do you think ..?
TV channel 29 lambda = 560mm
,,, and especially executed under this form...
