Everzone
Sector 5 Ghz Original - And Copied
53 posts in this topic
13 hours ago, Admin said:
There's no problem, I'll try to solve it...!!!
Ok waiting u
And please dont forget to send picture of the dbi gain of this antenna and the frequency
,,,for this antenna can you give these dimensions? ... ???
helo sir this antenna was having too much faulty dimensions so i draw a new one with good dimension im gonna send it to you now
,,,for which the antenna is working on the band 5-5,35GHz ... ???
the seller say that this antenna is 19 db  working from 5000 to 5,800
i have now a better dimension for this antenna do you want me to send it to you ?
and retest it for check if there is increasing in DB ?
i mean better dimensions 100%
,,,the antenna can not be so small ... how can it be PCB = 1,5x14x46mm ???
wait i will check the dimension
check nowww
ant.stl
,,,good, I think this would work ...
ok bro pleaseeeeeeeeee test it and let me if there any news
because i test it and printed to pcb board and i scan for 3 km , the Original board is still better i dont know whyyyyyyyyyyyyyy helpp
For such frequencies, the material from which the PCB is built, matters a lot...!!!
from fr3 pcb board 1 layer
,,, and the thickness and distance from the reflector...!!!
reflectror thickness 2 mm
vibrator to reflectror 3mm
