Simulation of antenna in CST Microwave
172 posts in this topic
Admin, got a question to you: recently I installed cst2019 and met a problem, it can not calculate 1/4 lambda transformator “wire above ground”.
AppCad gives preliminary results, but when I make a model in simulator it shows a weather.
 I would like to see your results in the * cst file...!!
32 minutes ago, Admin said:
I hope this helps you...!!!
No, it doesn't. What do you mean?
""" with the method shown above, you can delete the two ports...!!!
what for? I asked you to delete 2 PLOTS in THE PREVIOUS to Previous POST!
And the question was not about deliting ports.
Edited by vodkaman
this one
Admin, do you have a version? How to calculate quarter wave transformer in CST?
,,, my friend, explain to me, what you want to do with this quarter wave transformer in CST...???!!!
I need to conform antenna impedance (39 Ohm) and feeder (cable) impedance (50 Ohm). I need to do it with wire above ground.
