Simulation of antenna in CST Microwave
193 posts in this topic
Good time. I found an antenna model where two cylinders are connected by a separate element . A smooth curve is obtained. I can't find how to do this in the program. How can this be done?
Edited by Aksonx2
,,,go to Picks>Pick Face and...
,,,go to Loft>make 0.25>
Thank you very much, everything worked out. Can you tell me the characteristics of PET-G plastic for calculating simulation in the program? I understand that the Epsilon , Mu parameter is necessary, and some other important parameters must be specified. A search in Goggle gave an approximate parameter Epsilon = 3.1 for PET-G plastic at temperatures up to 180 degrees Celsius. Moxon designed an antenna in a plastic frame made of PET-G, the antenna turned out to be with a VSWR down by 50 MHz from the calculated one according to the program.
Dielectric Constant
1kHz -2.6
1MHz-2.4
On 07.02.2025 at 7:34 PM, Admin said:
Dielectric Constant
1kHz -2.6
1MHz-2.4
Thank you very much when I wrote to you, I also checked this parameter and the program actually showed the same value of the material = 2.4. I'll try to make a new calculation at 950 MHz instead of 915 MHz. If necessary, I will write about the results. Now there is an opportunity to work with a 3d printing designer. I'm exporting the antenna model to him in "step" format file. The designer adds plastic models to his program and sends them to me. It turns out to be a ready-made model, taking into account all the details.
This opens up interesting possibilities in the program. It might be possible to make something similar to a Fresnel lens :)
Edited by Aksonx2
22 minutes ago, Admin said:
,,,what is the password...???
Sorry!!! Password: 1progs
Edited by Aksonx2
Hello everyone, I am making a model of a spiral antenna. Please tell me how to make a matching element in the simulation program? A triangle that is curved along the radius.
3 minutes ago, Admin said:
,,,this it is(17x71 mm) ....!!!
Hello, dear Admin!!! I meant how to make such a figure in CST Studio? A right triangle that goes around a circle.
,,,hi, my friend, see that in this post (page 1) there is an example of how to bent a surface...!!!
an example...
bent.cst
,,,what is the diameter of your helix antenna...!!!
On 2/2/2020 at 4:36 PM, Admin said:
Besides frequency, is there any other reason you choose a discrete port over a lumped port sir?
You use WHAT WORKS (that'll be DISCRETE PORT 1st and WAVE Port at the end) Same for Solver mesh settings
Understood, Sir. Thank you for the clarification.
