VAS - 2.4 GHz Pepperbox 13dBic Antenna RHCP
48 posts in this topic
1 minute ago, Admin said:
,,, and that's, how you say ... ???
i want know distance between two crosshair antenna or any data that is new in papperbox antenna after merge two crosshair antenna
position
,,,0,62*lambda-----0,99*lambda
thanks
have you any datasheet about this or CTS ?
another question : which antenna  is better than for beamwith in same gain (13db)
1- dual-biquad
2- papperbox
33 minutes ago, Admin said:
now can you please simulate papperbox (not crosshair) antenna in CTS
,, only if you give me the dielectric characteristics of the pepper-box material...!!
please use dielectric characteristics of crosshair that you simulate
53 minutes ago, Admin said:
,,, the air is not dielectric .... !!!
yes
I think simulate pepperbox is not hard for you...!!
Edited by Admin
,,,, mojtaba, are you dealing with drones ... ???
no just hubby
,,, ready, that this is the end of this topic ... !!!
,,,tomorrow I will give the dimensions...!!!
,,, below are simulated 1 + 1 pepperbox antenna  at a distance of 123mm...
,,, twine crosshair antenna...!!!
ok
if you like in end simulate twine crosshair antenna and report dimension for 13db antenna
On 28/01/2019 at 6:09 PM, Admin said:
,,,and some construction details...
Hi.
Is it the matching netrowk of the pepperbox antenna? According to Alex Ibcrazy we need to rotate one of the antenna 180° and delay one cable 180° to make it work.I have no idea and no experience of RF.Can somebody help me?.I want to build 1280mhz Pepperbox Antenna.
11 hours ago, Admin said:
Sham, it would be nice if you read this...https://fpvlab.com/forums/showthread.php?3626-Crosshair-10-dbic-Circularly-polarized-antenna-tutorial!
,,, normally,it comes to 180 grd...!!!
,,,, and these would be the dimensions for some working frequencies...
,,, if you want an antenna on the frequency of 1280MHx,maybe I can help you
Thank you very appreciated.!!
Here is my 1280mhz Pepperbox.I don't know if the matching network will work and matched this two crosshair.I use rg179(75ohm) coax Lamda/4 *vf to match the impedance of 100ohm to 50ohm back to receiver.is it correct?
,,, be attentive to the coaxial cable portion with 75Ohm impedance...!!!
great job and good simulation work with CST.
the VSWR is ok but i want to know how about the axial performance? in my opinion the vswr can be wideband but the axial performance will be narrow band of crosshair antenna.
Edited by Chafer
