lrg
Petra LITE BOX HOME
Budget universal antenna Petra Lite Box c the dustproof and splashproof housing for 3G/4G USB modem. CRC9 connectors. F=1700-2700 MHz. GAIN=9dBi. Polarization X-pol. Standards: LTE-A, LTE1800, LTE2600, UMTS2100, WIFI.
Hi, buddy...!!!
You have the dimensions at this antenna... ???
The box has these dimensions... ???
 PETRA LITE BOX
Operating frequency range, MHz 1700-2700
Gain, dBi 8,5÷9,5
Dimensions without stand, m 0,2x0,2x0,06
Gain, dBi 8,5÷9,5
Days width, in horizontal plane, degree 56÷75
Days width, in vertical plane, degrees 56÷75
Ratio forward/back, dB15÷20
Isolation between the ports in the range 1700-2700МГц, not less 22dB
Input impedance, Ohm 50
VSWR in operating frequency range at the inputs, no more 1,6
Permissible power watts 10
The slope of the polarization of the received/radiated waves +45 ° /-45° (X-pol)
Yes, it looks like it works pretty well ... !!!
A window sill Internet access point was created based on the Petra Lite Box, which with a USB extension cable, but the real application of which I always questioned, but always saw a certain antenna potential, and now with the advent of AX-Box-3 everything in my head grew and my hands bore .
Another LTE boat was born, capable of catching a signal from a window sill for a 3g 4g USB modem, which in turn works with the AXR-1PoE router. This is basic, but there are pleasant things, for example, a sim injector.
Do you have the dimensions of the model?
On 09.12.2019 at 7:01 PM, Admin said:
,,,yes...!!!
Antex has a range of 1700-2700 with VSWR = <1.6, did you get a slightly different range, cover? or dimensions ?
Can I see your dimensions or file ?
,,, yes, it is possible, these are the measurements of the manufacturer...!!!
,,,,maybe my copy attempt needs to be resized...!!!
Turning a Petra Lite Box home antenna with a 10-meter USB extension cable into a street Internet access point with a 30-meter twisted-pair FTP cable is a couple of trivialities using the AXR-1PoE router, RJ-45 cable gland and the street option for attaching box antennas .
Dismantling the elements of the USB extension cord, four holes for the M4 screws, ripping the existing PG-7 hole to 20 mm to tighten the RG-45.
,,,,and this it"s AXR-1Poe router with modem...
Petra-9 turns into Petra-20
For the manufacture of a strong UMTS 2100 antenna, which it needed in a repeater gain circuit, must be used a small Antrax Petra-9 panel antenna.
Petra-9 is used as a service (internal) antenna, but with a little refinement it can become an irradiator for an offset mirror.
How close am i...?
don't know much about LTE range...
but i really like the SMOOTHNESS of this one...
 ,,, yes, this antenna is good ... you can also post cst * files...!!!
,,, these are the frequencies for LTE...
is it possible , Jomy ,...that it has TWO resonances ?...and that they are at 1.8 and 2.4 ghz...does it makes sense...?
9,5 DBI average from 1.7 to 2,6...
,,, the coaxial cable is connected in the center...
A set of equipment for  mobile Internet in the country or in the office. Desktop MiMo antenna of the domestic manufacturer Antex stabilizes the signal in the room, which increases the speed of the Internet connection. The maximum gain of the MiMo antenna is 2*9dBi. The kit includes a universal modem that installs SIM cards of any mobile operators. The modem is connected installed inside the antenna from which the cable is output (included 10 meters) and connected to the USB connector of the router. The router, in turn, distributes the Internet over a Wi - Fi network at a frequency of 2.4 GHz. Additionally, it is possible to connect up to 4 devices without a Wi-Fi module, via Ethernet wires (RG-45). The equipment package supports all 2G / 3G/4G LTE networks using LTE Cat technologies.4 at mobile connection speeds up to 150Mbps.
,,,the first option...easier to execute...!!!
Huawei E3372 Modem with Router and Antenna Petra Lite Home Boxhuwei 3G/4G Modem + Wi - Fi Router
