zach.antre
need of Dual Band antennas
Hello guys,
I am a wireless networks enthousiast and I really like mesh networks. I found this website by searching on how to build my own antennas (though I do not have radiowave knowledge, I am pretty good at building staff). This is my 1st post on this amazing forum and I have red almost all posts but I am not really sure if I have found what I need (too many information), so I am writting this post in order to get some help from people that have better knowledge than me.
I own several Meraki MR16 APs flashed with OpenWRT firmware and I would like to create a mesh network and provide free wifi to the people living in my village. The concept is to combine 2 MR16 on each place, 1 for mesh networking (backhaul) and 1 as AP.  There are several houses over 1km away and for that I would like to use high gain omni and directional antennas
The MR16 has 2 small dual band omni antennas
Ideally what I need is 2 MIMO Dual Band (2x2:2) antennas  (1 omni and 1 directional) but at least for omni I don't even know if it is possible.
for sure I need the antennas to be dualband and able to controll polarisation in order to avoid interference
So, any suggestions please?
"Well, but your access point has two antennas, one with vertical polarization and one with horizontal polarization...
Here is a side view of the 2.4GHz antenna.
Here’s the top down view of the 5GHz antenna on the MR-16 AP.
Both are F-inverted antenna...!!!
And what kind of antenna do you want ... and for what frequency?
Actually both radios use the same antenna for each stream.
I have tested them by unplugging them one by one.
The frequencies I need are for wifi 2.4GHz and 5.5-5.7GHz (for outdoor)
I need 1 dualband omni horizontal polarized
1 dualband omni vertical polarized
1 dualband directional horizontal polarized
1 dualband directional vertical polarized
Edited by zach.antre
,,, aaaa, okay, so it has separate antenna ports for both 2.4GHz and 5.5GHz respectively...!!!!
well, from what I have tested this is how is made:
1 dual band vertical polarized antenna
and 1 dual band horizontal polarized antenna
it has seperate antenna for 2 streams (150mbps each stream)
"So you need two MiMo antennas, one for 2.4GHZ and one for 5.5GHz...!!!
for 1 device i need:
1 omni antenna dual band vertical polarization
and 1  omni antenna dual band horizontal polarization
or
1 mimo omni antenna dual band (2x2)
for long distance device i need:
1 directional antenna dual band vertical polarization
and 1  directional antenna dual band horizontal polarization
or
1 mimo directional  antenna dual band (2x2)
I need different polarization in order to avoid intereferance.
If circular polarization have not this problem then I don't really mind.
But I think circular polarization has less distance
I do not know, you want a lot, why do not you look at this site, find enough antenna types...!!!
I think it's best to use two of them...
,,,or this...
,,,or maybe it's better so,panel with two-band antennas...!!!
,,,but without omnidirectional polarization....!!!
For which this panel antenna could be for the frequency range of 2.3-2.6GHz ... ???
