Antenna for digital TV
92 posts in this topic
Antenna for digital TV is no different from antennas for analog TV. choose from a large Ku.
Specify which channels are broadcasting UHF. the antenna should cover the range(500-800MHz).
This is a realization of VodkaMan friend.
Some improvements for this type af patch antenna UHF:
 Mounting studs M6 with nuts and washers. Line powering with ramps instead of fillets (I think smarter).
 Reflector rectangular 340mmx290mm, the distance between studs 120mm.
Patch - 208mmx208mm truncated cylinder 214mm installed at a height of 65 mm (the gap).
Director - 173.6 mm in diameter, at a height of 95.5 mm from the reflector (the gap).
Material - galvanized 0.5 mm.
Jomy, on the first message shows the antenna from Vodkaman. This antenna options is hard to move to LTE band 5 and 18?
,,, then about 800-900 MHz ... ??
But I think for the LTE antenna , needs a circular or elliptical polarization...!!!
You need an antenna like this....
the size of this antenna is big ? any way there is size reduction?
I think there is no other option to reduce the size of antennas - MIMO 850Mhz Band5 =UL 824-849/ DL 869-894 MHz
Okay, and finally, tell me what you want?
Something like that,,,,
,,,or like that....???
And what do you want with these images for yagi antenna?
I just showed how antenna. Yagi is very difficult to manufacture. Jomy, patch MIMO-850 the big? what size is the reflector?
Edited by chilanzar2
300x300mm
or 360x300mm
with one patch antenna gain is 9DBi, and if the second patch to put on top of the first patch, the antenna gain will be great?
No, only the frequency range increases....!!!
You can position two  patches-antennas at 90 degrees for the MiMo antenna
