Antenna for digital TV
92 posts in this topic
,,, no, my antenna is better ... !!!
,,,simply the best...!!!
I will give you a demonstration for the 470-820 MHz frequency band....!!!
Ok. Make it using the 75 Ohm connector I gave you today.
,,,let's see ...!!!
,,, for me a 75 Ohm connector is very simple to do >>> !!!
Hello boys
I think that building patch antenna for tv UHF band is a pure wasting of material
and it is large and ia heavy, it is something like you wish to drive a cae but u use truck..
there are far elegant solutions
For example like i do, i doubt in first what to build and now i am happy with reception with my double biquad
with aluminim wires and standard baloon transformer
,,, okay, but you can ensure a bandwidth of 350MHz .... ???
bandwith of 350Mhz ?
what is that ? i am not sure...here where i am there is no any TV station that emit on 350Mhz in DBV-T all of them are above 470MHz
so if you can pick up lower then you must recalc biquad dimensions which must be more larger
Digital terrestrial television (DTTV or DTT, or DTTB with "broadcasting"),,,for the 470-820 MHz frequency band(820-470=350MHz bandwidth  )
It is DVB-T - digital video broadcasting - terrestrial
ok so range is 350MHz,,,, so you mean is he can cover whole range
He can if the size is for 470MHz...
,,,that's it Super flat/thin antenna DELTA Н117А.F-5V...???
,,, and the results that do not seem too good...!!!
Spoiler
В вашей модели слева и справа пропущены два бортика. Рефлектор П образный.
Фото оригинального рефлектора есть в статье. http://dvbpro.ru/obzor-naruzhnoj-antenny-delta-n117a-f-5v/
В моей пробной модели бортики сделаны из фольги  единым целым с рефлектором. Высота их порядка 28 мм.
In your model, two sides are missing on the left and right. P-shaped reflector.
A photo of the original reflector is in the article. http://dvbpro.ru/obzor-naruzhnoj-antenny-delta-n117a-f-5v/
In my trial model, the sides are made of foil as a unit with a reflector. Their height is about 28 mm.
And of course look inside. The dimensions of the base reflector 256х287 mm:
And on the sides there are plates 28х269 mm. the Distance between them — 244 mm side
The overall dimensions of the resonator — 228х268 mm, its width in the middle slightly smaller — 210 mm.
The distance between the resonator plate and the reflector 29 mm.
Amplifier Board is soldered at a distance of 89 mm from the top edge:
20 minutes ago, Admin said:
Расстояние между ними - 244 мм на стороне
Здесь он похоже ошибся или измерил между торцами пластин. Реально между пластинами больше чем 244. Размер должен быть порядка 260 мм, то есть совпадать с шириной рефлектора
Here he seems to have made a mistake or measured between the ends of the plates. In reality, there is more than 244 between the plates. The size should be about 260 mm, that is, it must coincide with the width of the reflector
Правильный размер 244 мм. За бортиками на фото ими закрыты отверстия крепления рефлектора к корпусу антенны.
В моём варианте получилось почти 256 мм.
The correct size is 244 mm. Behind the sides in the photo, they closed the holes for mounting the reflector to the antenna body.
In my version it turned out almost 256 mm.
,,,okay Aurel,I"ll try to make a simulation with your wire TV antenna....!!!
", not TUL, I think this antenna is not broadband...!!!
,,, at the request of the" vars-cat "user, I tried to simulate this batwing antenna.for the 470-820 MHz frequency band..
Spoiler
Spoiler
