Antenna for digital TV
92 posts in this topic
,,, and the variant with cut corners...
Spoiler
,,, and a variant proposed by the user "com666"...
 I think I should test this mini-TV antenna...!!!
,,.from JM actualidades on YouTube...!!
On 15.03.2020 at 13:41, Admin said:
,, по просьбе пользователя" vars-cat "я попытался смоделировать эту антенну с крыльями летучей мыши для полосы частот 470-820 МГц..
  Скрыть содержимое
  Скрыть содержимое
Your batwing is good! But I do not have enough sheet Al, can I shift up to 730? Why should I cover the entire range! Sizes will be smaller.
Greetings group... I was given the schematic of an antenna that they say is the best in Europe at the moment, but I don't know what impedance this type of dipole has and if it will be as good as they say... could it be modeled and find out if it is as good?
,,,hello  Edel, a simulation could be made, but there are still some dimensions missing from the vibrator...!!!
,,,also mark the angles of the reflector and the directors' arms...!!!
Too bad... I owe you this, it's what I have on hand, maybe you want to try other types of vibrators, I've seen this one in similar models
Ahhh wait I found something....the reflector is in the image 60 degrees and the directors is 6.70 degrees
,,,you can show how the antenna is in real image..!!!
,,, it can't be better than this, but with the second version of the vibrator...!!!
,,,if you can, give me more constructive details on the first dipole version...!!!
Toole ... that's what I have for now, I'll keep looking. The vibrator that sends you as a test is from the Antenna PF5000 and this balum that I had not seen before, but of this if I have no more details
This is an interesting and surprising design - Tuning directores positions process looks  terrible, so much elements and only 14dBi. @Admin, Your version of the biquaod was better.
Now we know that this is a dead end road and that it doesn't work.
Edited by eco32
