Biquad Antenna
317 posts in this topic
I dont know what kind of biquad is this ,,but  biquad ia biquad
On 12/03/2020 at 7:38 PM, Admin said:
Something like that....
The velocity facter is introduced in kamda/4 ????;;
11 hours ago, Admin said:
...it must to be..!!!
Jomy in m willing to assemble 2  double biquad. Can you give me the distance between it and  the length of  cable attaattachment?
1)  l=k*lambda/4   k=(depending on the insulating material)...velocity factor
2)   the distance between 2xdouble biquad=(0,62,,,0,72)*lambda
Hello, I found interesting article how to increase gain of biquad (double biquad) antenna by adding a director (second biquad in front of first). Article about that method by Dragoslav Dobricic (YU1AW): Link. According to a user of one of the Polish forums, a double biquad antenna with added director may have a gain of about 16dB (Link). Can you check this informations in simulation? Thanks.
Erwin,this antenna is not as they say, look...
Hi Jomy. I would like to get the simulation of this biquad for 2.4
13dbi
HERE:https://martybugs.net/wireless/biquad/double.cgi (one of those and a HALF ,1.5 dBi more = 14.5dbi)
On 5/28/2017 at 2:39 PM, Admin said:
Only under that form I have now found
pcb simple biquad.cst
Sorry master, if this antenna is made with a thin sheet of aluminum, will it have the same gain or will it get worse?
,,, maybe yes, but you need other distances between the biquad antenna..!!!
How to determine the distance between the biquad antenna and the aluminum sheet? Or maybe you can help master?
More efficient (NO DIELECTRIC) , a little more gain , imho
1mm aluminum
size should be increased X,Y by 10% (1.1)
Dielectric used must be known (Boom and spacers)
impedance close to 50 from 2 to 2.5 ghz
Vswr should be adjusted (exact materials needed and Bandwidth)
"More efficient (NO DIELECTRIC) , a little more gain"
17 hours ago, clanon said:
1mm aluminum
This is a slot-loop antenna. it is not necessary to execute the slowing-down structure on such elements. can be done with wire elements.
12 to 15 dbi and a nice 50 ohms curve in the whole bandwidth...
show more details on the INFINITE like shape...
so it behaves  like 3 half waves SLOTS...?
(wideband)
What happens if that shape is multiplied into a flat BOX...?
(4 , 6 , 8 of those)
(wideband)
Big sizes... 15 dbi ~ 200*200*200 mm
On 6/13/2017 at 3:56 PM, efeksk said:
FR41mm pcb.
Frequency = 5800 MHz
Hi, I am new to this site.  I would like to build a Double Biquad Antenna for 920MHz. Could you please share the design and simulation for this?
,,,voiceofbusiness,,, the place of this type of antenna is not here, try to post in the right place...!!!
On 4/23/2018 at 10:03 AM, Admin said:
,,,no,
if you want for the 5.2 GHz frequency ,tell me...?!
Hi admin
I know the date of this post is very old, but if possible, do the design for the 5200 frequency as well
i want to make it
thank you
Edited by mojtaba.hdpr
,,, yes, it is possible, but you have to wait a little longer until I do a simulation for this frequency...!!!
