Biquad Antenna
387 posts in this topic
This is indeed much simpler and more stable over a wide frequency range. The idea with the directors is also not bad, perhaps with this the reflector can be a little bit smaller.
Updated version of the Biquad in a pot for 2.4 GHz, this time with a better impedance match over a wider frequency range and vswr starting at 1 ;-). But as mentioned before there are better designs out there.
Parameters
Quote
wsq="5.7" "with square"
lsq="26.6" "length square"
h="30.7" "height"
g="0.5" "thickness mat"
w="(l-wsq)/2" "with biquad"
ded="l/4-we1/2" "distance edge"
ded2="l/4+we1/2" "distance edge 2"
l="136.1" "length biquad"
e="5.3" "edge 3 biquad"
s="7.3" "hole diameter"
s1="43.4" "length slot"
sl="0.3" "slot"
x="248.2" "reflector x"
y="128.7" "reflector y"
we1="5.3" "with edge 1"
hc="177.0" "height collector"
ang="13.9" "angle collector"
You don't have sidelobes on the x-axis and quite large on the y-axis. Try resizing the reflector ;-) , this should help flatten the radiation pattern and raise the gain.You don't have X-axis sidelobes and quite large Y-axis ones. Try resizing the reflector ;-) , this should help flatten the radiation pattern and raise the gain (energy from the sidelobes will go into the main direction). The antenna is symmetrical and requires a Balun to connect the coaxial cable. It seems to me that this has nothing to do with the loop antenna (Kharchenko's bi-square), this one can be considered as a broadband dipole with a shunt or as a slot.
One of the simplest options for a balun is to lay a cable along the slot to the zero potential point (connecting the two halves of the emitter sheet) and leading it to the side of the reflector.
But this option requires a relatively small diameter cable, preferably with a TEFLON dielectric and an SMA flange crimped on it. Not everyone has such a cable. it seemed to me that at home it is easier to make the balun suggested by me on the previous page. You can multiply the dimensions in the project by 2.5 - 3 and get the dimensions for the range 1.7-2.7
If you adjust the dimensions, then the structure fits into the perimeter of a metal can with a diameter of 99 mm. This is a very simple and quick solution for home-made from scrap materials.
On 16.01.2017 at 4:36 PM, Admin said:
,,,a biquad antenna on PCB(10,5dBi) and panel antenna with 4biquad(16.5dBi)...
Hi @Admin
Could You Please symulate it for a 1296MHZ (23cm ham radio band)?
I will try to cut this shape in laser from metal sheet. Thats my idea to add N or SMA  connector. Lets fin out, how it will work with comparing to my biquads
Edited by eco32
,,, these would be the simulations and dimensions...!!!!
Thank YOU!
I see the qain is smaller than I got, how it will be with 90deg, i belive that is possible to get 14dBi
On 13.05.2022 at 10:38 PM, Dr. Pepper said:
Biquat + Horn for 2.4 - 2.5 GHz & optimized for gain
WOW!
@Dr. Pepper You got 16dBi !!!  I got only  14dBi
632865e23f74f_1296MHz-13.9dBi_bbokie_pudeeczko_m.jpg.025601b41d659269c6944aeed234aeb4[1].jpg
I cant change angle of the box in Matlab, thats my limitation.
I like to try it on 1296MHZ
@AdminMay We have other section for 1296MHZ 23cm band antennas?
,,,yes, maybe we should..!!!
The angle of the box is very important. It influences not only the gain but also swr, bandwith and so on.
That's my version of this antenna:
(BOX completely incidental, should be other size)
size
55x38x26cm
bottom : 51x34cm
Eco, the box is very big and has no point, and the biquad antenna is connected like this...
On 11/2/2018 at 5:00 AM, Admin said:
this file type is not good...??
biquad.dxf
biquad.gbr
I just made this antenna and i can only say it works like a charm! and very easy to do.
Thats the biqaod, is there an chance to achive circular polarisation with two biqoad or biloop antenas using only phase shifter?
(two biquads oriented at 90 degrees to each other)
Add to previous post:
I know that it is possible with dipoles, because there is an opposition phase on the "arms", I have no idea how to do it with a biquad, it has same phase on opostit corners
In 5GHZ Wifi projects once i saw this twisted construction (I do not know what the reason was, possibly to save space, but maybe something else, I am not able to simulate it yet. But I will make a prototype for measurements)
Thats "normal" biquad and "twisted" biqiad:
Other example of biquod (it's not good to follow him this time), of cours it can not work simultaneously, and MDF as isolator is bad idea.  I think he said something about how this antenna will work in circular polarization. He did not show the chart from the analyzer.
"In this video I show you how to make a biquad antenna that works in the horizontal and vertical simultaneously. This can be of benefit if tracking a constantly shifting object such as a quadcopter. It is also important to note that although the elements in this build are circular (one full wavelength) the biquad still propagates as a linear polarized antenna."
Edited by eco32
it should be possible with a 90 degrees (velocity factor of coax x 1/4 wavelength) between both antennas (but interactions should be simulated)...
20 hours ago, Admin said:
,,,SEE THIS...!!!
Yes, Thank You!!!, it looks like his cross biquad/biloop has 8dBi isted of 10dB from single biquod, without e-field chart it's hard to tell if it's circular polarization in this design there are no phase shifters. In my opinion it has linear polatisation. (I don't have to be right, maybe there is something going on there that I have no idea about)
Just only for Example: S-band circularly polarized crossed dipole antenna for automotive applications
I see this antenna is connected to the reflector to the other side of the feeding. Why? and what is the difference between connecting it to ground or not at that end position. Thanks
YES you treat it like a simple dipole (but polarization is 180 degrees inverted for a double quad)
Then to get Circular Polarization , you need to retard 90 degrees the wave at each quarter making a 0 90 180 270 rotation (for this the easiest approach is a Quarter wave length (dielectric in coax included) from One biquad to the other...
Double lineal here , NOT circular "The polarization of the emitted signal depends on the spatial location of the antenna. Horizontal - horizontal, vertical - vertical polarization. [4] The horizontal position represents when both squares are next to each other, the vertical position is when both squares are placed one above the other."
DoubleBiquadOmni-Antennafor2.4GHzWirelessLinkApplication.pdf
once again:
Dipole has oposit phase on the arms, biquad has same phase on the both ends, trick with phase shiter will not work here.
12 hours ago, eco32 said:
once again:
LOOP should be CLOSED at feeding Points...
then , EACH Loop should be feed with 90 degrees phase difference
No one did it with biquad
Photograph-of-fabricated-prototype_W640.jpgConfigurations-of-the-proposed-broadband-CP-antenna-array_W640.jpg1-s2.0-S1110016820304440-gr6.jpg
Edited by eco32
