Biquad Antenna
370 posts in this topic
Where did you get it from?...give some more clarifications...!!
On 29/11/2023 at 7:15 PM, eco32 said:
No one did it with biquad
Photograph-of-fabricated-prototype_W640.jpgConfigurations-of-the-proposed-broadband-CP-antenna-array_W640.jpg1-s2.0-S1110016820304440-gr6.jpg
nope...BUT those complex feed networks steal gain (several db)
,,,"clanon","eco32",,,,,,,the place of these antennas is not here, possibly open a new topic...!!!!
a)New aproach, converting biquad to biloop, not tested yet
quick and careless soldering
b)Four biqads for array, eventually there will be six (I have 1:6 powe combiner, thats why six)
WhatsApp Image 2024-03-22 at 14.14.39.jpegWhatsApp Image 2024-03-22 at 14.14.38.jpeg
gooood,,,for what frequencies were the antennas made...??? the biloop antenna needs a diameter of 40.5mm for the frequency of 2.442 GHz
1296MHz, previous tests have shown that the antenna also works on the higher bands. I will take two on the VNA and do an S12 between them, then we will know what it looks like.
6xbiqod project has name "MATHYLDE"
Edited by eco32
A very old design from the time when there was no access to VNA or simulation programs. I'm not sure if this design makes sense, but it looks cruel
(purpose TV broadcast)
On 11/20/2023 at 11:19 PM, eco32 said:
Thats the biqaod, is there an chance to achive circular polarisation with two biqoad or biloop antenas using only phase shifter?
(two biquads oriented at 90 degrees to each other)
what a biquad?
It look like a "mother" of all biquads,  wild dualband antena , from the propostion il look like it is for ~ 106MHz  500Mhz.
(this design may be suitable for LTE420, LTE450  + Tetra and other trunkng systems VHF+UHF)
Edited by eco32
"From R-409, on a common reflector there are two antennas, one larger 120-240 MHz gain 9 dB, four smaller 240-480 MHz gain 13 dB."
biquad  or "double square" is also called "антенна Харченко" and searching for this name in google opens the gates of hell!
23 hours ago, eco32 said:
"Two-element in-phase antenna array, zigzag radiators with a reflector (DB-11). Frequencies 120-240 and 390-429.8. Were on the R-415, R-419.
Army VHF antenna DB-12 from the R-415 radio set. It is a broadband dipole. The dipole arms are 20 cm each. Operating frequencies from 390 to 430 MHz."
VHF 120-20MHz in VHF 9dBi
UHF 390-429.8Mhz  in UHF 13dBi
Gain of those version with grid is unknown
,,,,eco32, it would be good if you could give some dimensions...!!!
It exist in R-415, R-419 manual, it is out of the google searchnig, i did not check Yandex.ru yet. It exist in paper version, some hams from my area has it, it is not eassy to get.
It may comes from Radio Factory Omsk
@Admin
"From R-409, on a common reflector two antennas, one larger 120-240 MHz gain 9 dB, four smaller 240-480 MHz gain 13 dB."
"Two-element in-phase antenna array, zigzag emitters with a reflector (DB-11). Frequencies 120-240 and 390-429.8. Stood on R-415, R-419.
Army VHF antenna DB-12 from the R-415 radio kit. Represents a broadband dipole. Dipole arms are 20 cm. Operating frequencies from 390 to 430 MHz."
,,,this is not a biquad antenna...!!!
Hi. Can someone explain to me why you make the PCBs of the antennas like in the first photo and not like in the second? I'm new to this and I can't understand this choice.
,,,the antenna in the first figure has a wider frequency band...!!!
Is it possible to say that an antenna designed for 5645 MHz with a narrow frequency band is more efficient than an antenna designed for 5645 MHz with a wider frequency band?
Thank you for the answer!
,,,no...!!!
15 minutes ago, Admin said:
,,,no...!!!
Thanks!
