Biquad Antenna
309 posts in this topic
Okay, then give me your sizes at biquad...!!!
2 minutes ago, Admin said:
Ne tür PCB var?
Can not you design your pcb design for 2.4 GHz at 5.8 GHz?
PCB FR4
Thickness = 1mm
Copper surface thickness = 35 μm
Okay
But you have to wait a bit
Reflective reflector panel size 51x51mm
Bi-quad height = 17mm
Bi-quad Width = 33mm
1 minute ago, Admin said:
Okay
It's not a problem, dear friend.
But will it take too long?
But why do you want 5,8ghz, that's the upper limit of the band, I think you need 5.65ghz
No. It should be 5800 MHz center frequency.
It will operate between 5700 MHz and 5900 MHz.
But the center frequency will be 5.8 GHz
I'll share some pictures with you.
Pictures of pcb antennas I have built.
But the results are pretty bad.
As you can see from the analysis in the picture, the center frequency of the antenna is 5430 MHz.
Actually, I did my calculations at 5800 MHz :)
It was a pretty unsuccessful job
But here you made the copper wire antenna
Measure from outer path to inner path 11,64mm
Do you think it should be 11.17mm?
Yeah, I made a copper wire antenna. But it's a tough job. And it takes a lot of time. I can not always adjust the copper wire length to the correct size.
OK.
I will make a Quick Draw and share it with you
Mate.
I made a drawing according to the measurements she gave with Solidwork.
Would you please examine it?
16mm circle diameter can not adversely affect VSWR?
Yes, I will do a simulation with this configuration ...with 0,75 not 1.5mm
Please send me the igs (iges) file from solidworks for faster simulation
Do you want better than that ???
WOOOOOWWWWWWW.
It is so perfect
Do you say the size of the pcb
Please
Edited by efeksk
this
I look forward to the figures you have for building your pcb.
I want to build it and test it tonight.
Please
Please
Please
even better...
Please
Please
Please
Okay
