Biquad Antenna
309 posts in this topic
If you want to start this hobby, you should microquadrocopteral. Can be flown both indoor and outdoor
Also, the risk of breakage is small if you are small and crash.
I will write you the materials you need, my friend.
Derleme yapacağım ve size en uygun ekipmanları satın almak için bağlantılarla birlikte excel listesini gönderirim.
I will never forget this goodness.
One question....
Do you use the CST Studio program for antenna design
It's really a great program. I would like to learn a lot
Edited by efeksk
fes
If you know SolidWorks, it's very easy to learn CST Studio
I know solidwork well. I will download cst and dig it. I think cst lessons are useful for forum
And the other variant,,,
Dude, you are absolutely perfect. I built the first Antenna and tested it. The results are great.
Another solution you can not find ,,, ??
No metal screws,,,!!
Put insulating spacers ... !!!
new form on *igs file
new form.igs
Efeksk, can you tell me the dielectric constant to FR4 you have?
I have taken dielectric constant= 4,43 ,,,, maybe this is the difference...!!! but I do not think too,,,!!
No. Already on average between 4.25 and 4.60. Such a small dielectric constant does not affect the frequency.
"Then metal screws are to blame," !!!
I would like to manufacture this design with fr4 of 1mm thickness. What about you?
,,,no,try without metal screws ... !!!
These measurements were made without bolts.
I will send you measurements made when you have bolts
Then everything changes...!!!
I will try this option too, !!!
Component specified as abs.
FR4 Epoxy material. It's very different from plastic material. No choice between epoxi options
Which antenna is more effective at 5800 MHz frequency over long distances
