Patch Antenna on PCB
The high quality Patch antenna for 5.8GHz receiver.
Can increase the range of 5.8GHz transmitter
This 5.8GHz Right-Hand (RHCP) Circular Polarized patch antenna was custom-designed for the FPV market. Light enough to be mounted directly onto an FPV headset including the FatShark Goggle system or Uno and Duo FPV receivers.
With a much wider beam than it's 13dBi cousin, it easily has double the range of a standard SpiroNET Omni antenna.
Specs:
Circular Polarization: Right-Hand
Band: 5.8GHz ISM
Gain: 8dBi
Beam width: -3dB at +/- 45 degrees (H + V) (90 degree total)
F/B Ratio: >356dB
VSWR: < 1:1.35 at 5800MHz
Impedance: 50 ohms
Weight: 7g
why in the box each elbow is cut slightly?, can explain to understand the reason
This figure is posted only to show the connections (there is another type of antenna)
what is this antenna can be modified into a larger gain?
may be give director on front side
Edited by acri
 I do not think so, maybe only if the reflector grows a little,,,!!
What are the SUBSTRATE , dielectric constant...and loss...? (Rogers...?) which one...?
