aurel
BatWing antenna 2.4 ghz
352 posts in this topic
I don't see that here anyone post something like this .
I made it not very precise but dimensions are standard
i mean for such a antenna are
And here are dimensions..
I use this time 2.5mm2 copper wire, vertikal wires are 0.75mm.
I simply replace biquad shape with this one ..so distance from reflector is 17mm
,,,good, I know the idea but more interesting would be if it was used as an omnidirectional antenna...!!!
Hi Jomy...
i even don't know that such antenna exists before ...
here in my country there is no such a antennas used for big transmitters the our uses wave guides with weird panel antennas.
This small work very well ..in fact work better than ordinary biquad
,,,,good, I will do a simulation with this antenna...!!!
Look
I just calculate dimensions given from this old hungary site and
my antenna in practice work very very good for vertical polarization
even i read somewhere that this antenna is best for horizontal polarization and is not
recommended for vertical.
as i said before distance from AP is cca 400 m
and signal strength is for 10% better than with ordinary biquad
do you can explain that for me?
So as suggestion ...anyone who wish to try
remove your existing biquad from antenna and solder this element then check signal strength!
Ok
i use it with reflector
ok ..resized...
Is that mean that sizes from old paper picture are wrong?
mostly ALL parameters CHANGE when you add a reflector...Z (Real and Reactive), Fr , Gain , etc...(imho)
Bat wing antenna
"Batwing antennas generate a horizontally polarized signal. " "The "batwing" shape of the elements is used because it gives the antenna a widebandwidth of approximately 20% of operating frequency at a VSWR of 1.1:1"
1 hour ago, aurel said:
Ok
ok ..resized...
,,,,show me from where did you took the picture ...???
Clanon, yes that I know, but the dimensions .... ???
,,,that's the reality....!!!
,,,but that's for the 75 ohm impedance...!!!
Quote
Ok
I can build this one again ..no problem ž
BUT how you get  0.5 lambda  that is 46 ...instead of 60 mm ?
and how you get  0.6 lambda that is 59 mm --- 72 mm ?
And  joMy ..i found on several sites that is stated that batwing have only 3db gain
so if mine have 5 that is better..he he !
I will try to build UHF TV version with aluminum wires to see how work as TV antenna with horizontal polarization !
Quote
Yes  it is for 75 ohm..and i use 75 ohm cable
,,,simply the best. from comm666 user..!!!
Yes i see that image before ..
Jomy ..what is the distance of inner wire
i assume 10mm ?  id benter is on 30 mm
Edited by aurel
WOW
11dB ..that is very very good
..and the dimensions are ...in the image above or ?
