aurel
BatWing antenna 2.4 ghz
352 posts in this topic
the slit horizontal means the antenna is emitting VERTICAL polarized signal you'll see it as 2 or 3 db of increment on the reception side (vertical dipole) LineOfSight no reflections (reflections might have ANY polarization)
I installed the batwing on the remote control with a slit vertically, on the copter the reception is also vertical, it turns out I need to redo and install the farting slot horizontally .
Thank you clanon !
On 24.01.2021 at 11:37 AM, Admin said:
,,, a simple Batwing antenna made of thin sheet recovered from cans...!!!
,,,the *cst file...Pathe Batwing.cst
Hello everyone. So this is the best Batwing version for today?
and the option of power supply №2 and №3
4Ne42Us16Ck.jpg?size=2560x1920&quality=9
https://vk.com/club178486580?w=wall-178486580_2581&z=video-178486580_456239178%2F1e766e6607e42fef98%2Fpl_post_-178486580_2581
1st
but the difference will be small and not the fact that it is particularly measurable
5 hours ago, devton said:
1st
if I build it (which i WON't) I would pass the cable STRAIGHT ( NO angles ) from the reflector's CENTER and solder it from BEHIND...(but that's just me) need to simulate to confirm...Like i did on the parabolic feed...of course you need to fix the reflector without the bolt in the middle or make it HOLLOW
19 hours ago, Sl4va said:
he is using 3 Different cable length in this antennas
so IF you try to use cable length from #3 type (best SWR on video) AND use this cable length with connection option #1 it will be the best
NON PERIODIC ( non resonant ) CABLE lengths shouldn't be a problem (only for signal loss , bad connectors, too long , bad quality losses)
it's just an interaction between the VNA hardware and the cable...i think...
CORRECT ME if i'm wrong.
only practice will show...but i still think: cable length from #3 on video and conection scheme from #1 is the best option
Batwing "folk antenna". At the end of the video, a test. 130 megabits issued in the basement in the room
Interestingly, and if 4 pieces of such batwing are connected together, how to match them?
or
Edited by Sl4va
31 minutes ago, Sl4va said:
Have the last messages been deleted?
,,, yes, on this forum you can find enough ways to connect 4 antennas..!!!
Does anyone have any thoughts on how to make a batwing mimo irradiator
Edited by Sl4va
,,, maybe so ...
,,,or so...
,,, this happens at cross polarization...!!!
,,, but by changing the dimensions a wide band of frequencies can be obtained...!!!
Does 1800MHz need a larger size?
,,, of course, I will try to design a batwing antenna around this frequency...!!!
,,, okay, now I'm getting to work...!!!
,,, you can make something like that...???
...1 Crossed Dipole Batwing Antenna
,,,2x2 Crossed Dipole Batwings Antena
The antenna turned out to be very beautiful. And what are its dimensions?
P.S. And if you put it in a cup (cut bucket)?
,,,what bucket do you have ... ??
,,, some dimensions for buckets...
