aurel
BatWing antenna 2.4 ghz
351 posts in this topic
,,,this it"s...!!!
,,,another achievement of com666 user...
Very good,very good
I replace all biquads i have (3)  with batwing because it gives better resulats.
BatWing Release v2...
I am in processof building your version with wires
so i will see how this one work..
i hope better than mine !
,,, and an improvement for the batwing transmission line...
Dimensions of the batwing antenna by different authors....
,,, and after successive simulations, I reached this optimal size ...(by JOHNSON)
so yes...
,,,so no...
,,,batwing with cut corners...
Spoiler
Its kinda professional
On 2/15/2020 at 9:41 AM, Admin said:
I posted for you a Bester antenna on 1800mhz
,,, and finally, the latest UWB batwing  antenna model is optimized...!!!
6 people like this
„, for simplification in construction it can also be so...
,,,or so...
,,, if the adaptation line is elliptical, a wider frequency band is provided...
,,, constructive details....
CST file,,,
batwing elli.cst
And seeing this, I decided that a rounding of the corners is preferable(radius = 4 mm)...
,,, and by adding a batwing director the front-to-back ratio is emphasized...
A batwing antenna and a reflector with wings....
,,,and here is the simulation....
batwing simply.cst
Practical realization with laser cutting from "com666" user...
,,,named Covid-19,,, after a moment of inspiration, I managed to configure a new Batwing type antenna that provides a wide frequency band and a VSWR factor <1.5...
The antenna is made of round cut galvanized sheet, cut triangularly and rounded corners..
Covid-19
,,, if the angle  of 90 degrees is increased , a  good uniformity of the frequency bandwidth and impedance of Batwing-Antenna can be obtained...
angle=100 degrees
,,,Covid 19-1
angle=111,5 degrees
,,, after successive attempts at optimization, I managed to establish the right dimensions for this Batwing antenna(Covid-19), designed by me...
,, another form of batwing antenna...
batwing new.cst
it can be shaped from liver pate caps(95mm-diameter)
