aurel
BatWing antenna 2.4 ghz
351 posts in this topic
On 20.03.2020 at 0:08 PM, Admin said:
A batwing antenna and a reflector with wings....
,,,and here is the simulation....
batwing simply.cst
looks like perfect antenna for travelers - 12dbi, super-tiny, can be used for wifi and LTE
bravo!
,,,a Batwing in a  bucket(D=290mm;d=154mm;h=200mm)...!!!
batwing simply.cst
still this is the best - such a tiny package and 12dbi, optimal radiation patern
and i googled - it got low SWR in wifi2.4 and WHOLE most popular 4G bands all over the world (1.7...2.7)
i am going to produce one for myself. from tin. and glue it to tiny, but very tough plastic box for microwave oven...it is gona be Perfect traveler antenna - tiny and good for wifi and 4G
You could use HINGES for the sides , and fold'em BACK for transport...(Or make it for fast assemble and dis-assemble...)
It is curious whether it is possible to make an irradiator out of batwing using the "mimo" technology. For example, crossing them.
,, yes, it is possible but with a different geometry of the bowtie antenna....!!!
I will try to simulate such an antenna on a double-plated PCB...!!!
2 часа назад Админ сказал:
,, да, это возможно, но с другой геометрией антенны бабочки .... !!!
Я постараюсь смоделировать такую антенну на двойной плате ... !!!
Thank!
:D
Like the picture?
I saw your picture earlier on another forum
and did something similar at random (90 mm) :$  but haven't tried it yet. Now you need to redo it according to your size
Edited by Sl4va
,,, this is the cst* file , for Batwing in the bucket ,,,
new batwig.cst
,,, and some dimensions...
Thank! I have seen. But I do not have programs that can open this type of file :/
What program do you have to open a file?
Kompas?
,,,below I send to you a *dxf.file...
batwing.dxf
Kompas?
I don't have any, now I'll try to download Compass 3d
Kompas?
"Compass" program was unable to open the file (((
I don't think this is possible.......!!!!
I'll try to install - CST Studio Suite 2019 SP3
Edited by Sl4va
Success!
Show me the result too
Sl4va,this is about the antenna, not the satellite dishes, so I will delete your post...!!!
Don't forget PORT ISOLATION , should be kept higher than 20 db ...even more to get MIMO speeds...(that means physically apart antennas and radiation at 90 degrees never OVERLAPING )
,,,that's how it should be...!!!
and what about port isolation, db?
WOW!!! Super!! thanks
This is the birth of a star!
And what are its indicators: Gain, VSWR, how to power it?
Based on the above, I started to come up with another scheme
im open file is topic -
