aurel
BatWing antenna 2.4 ghz
352 posts in this topic
,,, okay, so the program works and you know how to work with it...!!!???
unfortunately I don’t know, I have no experience. But I will look to understand
you got few sets of sizes for BatwingS in this thread
you can just make it, you do not need program for this
:( these parameters / calculations and dimensions are not available
this 2 crossed even better...because almost no overlay
For now,,,this it"s the best...!!!
,,, let's see further ...!!!
if used as an offset antenna feed - the size is too big
Theoretically, can it be done on a double-sided PCB, by etching?
I made these a month ago.
Made for these sizes:
Material - copper sheet, 0.6 mm thick
Edited by Sl4va
But what if you put it in a reduced size "bucket"
by type as below picture
Edited by Sl4va
I have another idea....
put them crosswise and you get a decent distance between the points of contact. Maybe this is better?
this is some shit
just maki this MIMO "nazi cross" with small flat reflector (without sides):
Edited by devton
Initially, I started a conversation Batwing, how to compose for a satellite dish in Mimo
one more time - to make irradiator for satellite dish just just make this MIMO "nazi cross" with small flat reflector (without sides)
MIMO "nazi cross" with small flat reflector = satellite dish irridator
You won't isolate by tweaking ONLY the feed point...the WHOLE electromagnetic diagram must be consider (All irradiating elements and surfaces)(for ISOLATION that is)
SIMPLY put...: TWO COMPLETELY SEPARATE ANTENNAS are better (for ISOLATION of Ports) than two in the same cavity or close to each other...ALWAYS
But what about Kroks and Antex? They are mimo
On 20.07.2020 at 4:05 PM, devton said:
this is some shit
I wanted to show that it was so. Bend the middle so that the butwing petals lie in the same plane and do not touch
fetch?id=226684&d=1529518723
not sure you can feel the difference if you put one batwing 2-3 mm above another or use this fancy band in the middle
are you going to use it for 4G? if so, there will be no difference
Edited by devton
Yes, for 4g!
And about the intersection: I found a pair of intersecting feeds on the internet, just like the Batwing in the admin's photo. And one resembles the shape of a batwing.
Calculate its size. Who can help with this?
Edited by Sl4va
add spoiler
Sl4va, post the source of this antenna...!!!
outlined the contours in Photoshop
Edited by Sl4va
17 hours ago, Sl4va said:
Yes, for 4g!
  Reveal hidden contents
10 hours ago, devton said:
The administrator wrote that improved models with rounded corners are better
