aurel
BatWing antenna 2.4 ghz
352 posts in this topic
18 hours ago, Sl4va said:
The administrator wrote that improved models with rounded corners are better
yes,if you can find all sizes, just put one 2-3mm above another (and rotated 90 degree)
and yes it is better, but you will not feel the difference in real life in 4G
so choose any and JUST DOIT!
On 19.07.2020 at 6:50 PM, Admin said:
For now,,,this it"s the best...!!!
,,, let's see further ...!!!
And the size? The same as usual 102 mm? I think it's big to use as an irradiator
On 22.07.2020 at 0:58 PM, devton said:
In appearance - this one is perfect!
Edited by Sl4va
59 minutes ago, Admin said:
,,,yes,as usual sizes...!!!
is it possible to somehow reduce? So that the size is comfortable for the irradiator
yes just reduse backplate sizes to comfortable for the irradiator sizes
Will the VSWR parameters change?
On 04.02.2020 at 11:35 PM, Admin said:
,,, and after successive simulations, I reached this optimal size ...(by JOHNSON)
can you model this sizes antenna with your reflector with wings?
not much...only dbi will change
On 6/9/2020 at 2:33 PM, Admin said:
Covid-19 на печатной плате ...
,,, * дх файл ....
PCB Batwing.dxf
Диаметр платы печатной платы и дефлектора составляет 130 мм, расстояние между ними составляет 35 мм? как реализовать MIMO, сделать два одинаковых дизайна и расположить их на 90 градусов, подскажите пожалуйста? And what configuration would be effective at 1800 Mhz?
The diameter of the PCB board and the deflector is 130mm, and the distance between them is 35mm? how to implement MIMO, make two identical designs and place them at 90 degrees, please tell me? And what configuration would be effective at 1800 Mhz?
,,, something like this, with a distance between the centers of batwings>103mm
1 minute ago, Admin said:
,,, something like this, with a distance between the centers of >103mm
Is it better to lay the cable like this? As, I understood better the directional diagram
,,, the connection as in my picture above, is the most suitable...!!!
1 hour ago, Admin said:
,,, как то так, с расстоянием между центрами крыльев> 103мм
What are the best dimensions for a rectangular reflector?
Made the first prototype
Edited by Sl4va
add SPOILER
2 minutes ago, Admin said:
,,, adds a conical reflector...
hello! can you calculate this conical reflector with Exactly this batwing:
I am thinking of doing this
i mean radiation pattern and Ohms of that specific batwing with this reflector with wings
Sl4va,,, try it, but it's a bit hard to do...!!!
