aurel
BatWing antenna 2.4 ghz
351 posts in this topic
1 hour ago, Admin said:
,,, adds a conical reflector...
so can you simulate this backplate with wings with this batwing:
i need SWR graph frrom 1700mhz to 2700mhz
I've done this before.,,,!!!!!!!!!!!!
no, you did not model your Wings Reflector with Exactly this simple batwing:
please combine it,model it
2 hours ago, Sl4va said:
I made another such option
do you have SWR-meter to test them?
No. I make them according to the drawings -
On 15.06.2020 at 0:55 PM, Admin said:
,,, after successive attempts at optimization, I managed to establish the right dimensions for this Batwing antenna(Covid-19), designed by me...
but there is a drawing of this (file for CST Studio)?
Admin, help my ?
32 minutes ago, Admin said:
,,,, do you want this ... ??
Yes, with such a reflector. But the VSWR is good, in that it is higher.
P.S. according to the Pythagorean theorem, I calculated that the upper diameter of the "bucket" is 18 cm (more precisely 17.3 mm). if the base is 13 cm, and the board height is 7 cm, with an angle of inclination of 120 degrees
Edited by Sl4va
21 minutes ago, Admin said:
,,, see if these files help you..
my batwing.dxf
patch batwing.dxf
Thanks. file extension * dxf, for which program? CAD programs?
maybe there are such files for CST Studio?
 any CAD programs or Kompas program...!!!
Yes, your cone is better,,,,
and the VSWR has not changed?
VSWR ,,,it changes a little...!!
2 hours ago, Admin said:
,,,,my simulation...with cone dimensions=>D=154MM;d=120mm ; h=50mm
c=70mm, a=66 mm, b=23,32 mm
gGNEZKpQGdG7Os4ieT2nG2FLiScJVgfXTEYA0Voc
if we take a base of 120 mm, ∠ 120° then the upper diameter should be 23.2 + 23.2 + 120=166,4 (166 or 167) mm
try to simulate like this up Ø167 mm
Edited by Sl4va
my batwing.dxf
patch batwing.dxf
SWR and sizes are beautiful! but it is hard to produce :(
can u model this simple batwing with simple reflector
batwing:
square reflector with wings:
,, hey, people, I'm not here like a robot, try to take what I offered you on this forum...!!!
,,, search and you will find what interests you...!!!
Made another option according to the administrator's sketch
Admin, may I ask you to simulate the batwing antenna as a feed antenna to offset parabolic mirror please?
,,, this do you like ,,, ?? parabolic offset 800mm
[image removed]
Yes, thank you very much! Really appreciate it!
I see the simulation data is for 2150 MHz. I'd be grateful if you could do it for 2442 MHz. Well, I don't think it will change dramatically because the batwing is wide band.
