aurel
BatWing antenna 2.4 ghz
351 posts in this topic
,,, yes, the gain is about the same on the whole frequency band...!!!
Looks very competitive to the Bester antenna.
I think I could put one to the test. But I've found that this drawing differs from content of the DXF files you've published later. So which one is correct?
The DXF as my QCAD sees:
,,, yes, that's right. my drawing is the good one...!!!!
I still do not understand which is correct?
or
,, my drawing is correct...!!!
 I do not know why the transposition in cad programs does not respect the reality...??/!!!
This is exactly how (like the bottom picture) opens in Compass 3D
,,, the antenna profile must be made on Kompass program..!!!
so in it and open your file
,,, yes, I translated * dxf file from CST to Kompass and it doesn't seem to match..!!
can you share the file from CST?
On 7/17/2020 at 3:47 PM, Admin said:
,,, this is the cst* file , for Batwing in the bucket ,,,
new batwig.cst
,,, and some dimensions...
Okay, here it is. But it looks different from your drawing. Simulation screenshots seem match your drawings too.
What am I missing?
covina.dxf
Oops, the ellipse smaller radius is 49 mm, of course. The shape shows it correct, but the drawing dimension is wrong. Please use the updated DXF for reference.
covina.dxf
,,, not,,, small radius of the ellipse => 49/2 = 24.5mm and large radius of the ellipse => 95/2 = 47.5mm
             the center of the ellipse = 110mm from the 0y axis
 I thought my picture above was pretty clear...!!
I'm sorry, but this doesn't converge into anything practical :-(
Help needed.
,,, yes, you're right, my mistake..!!!
   the center of the ellipse = 110/2=55mm from the 0y axis
On 20.03.2020 at 0:08 PM, Admin said:
CUTE! what about SWR? measured with swr-meter?
,,, this is the comparison
between bester  and batwing antenna...
This is your batwing made in russia! Wow!
p.s he just a little bit mess with reflector angle
,,,this batwing antenna is my project...!!!
hm...what if you try to model Batwing with 90 degree 2d-corner reflector?? 0_o
corner reflector antenna with Batwing instead of dipole!
0.36...0.4 wavelength from corner top to axis of batwing
batwing plane in plane of corner's bisector
dude used your Batwing to get 5.8  GHz...can you show simulation for your Btwing on 5.2-6GHz?
