RF Elements StationBox 5 17dBi MIMO
RF Elements StationBox 5 GHz 17 dBi MIMO is a plastic enclosure with integrated MIMO antenna 17 dBi, in which you install cards in the routers.
The case is designed to create weatherproof access points that are installed outdoors.
Quality ABS plastic material the case provides reliable protection circuit Board router from moisture and sunlight. StationBox can be used at subzero temperatures.
StationBox secured with plastic ties that come in the kit. To adjust the case at different angles you can buy a special mount NanoBracket.
Built-in antenna 17 dBi designed to operate on the 5 GHz frequency and provides high-speed data transmission technology MIMO. To connect built-in antenna to the router using pigtails (adapters) that are purchased separately.
Features
Case
Weight:372 g
Dimensions:19 × 5 × 18.7 cm
Material:ABS plastic, UV-stabilized, weatherproof
Antenna
Frequency:5 GHz
Gain:17 dBi
Technology:MIMO
Compatibility
MikroTik:RB411, RB411A, RB411AH, Crossroads
Ubiquiti:WISPstation – possible to install 2 PCs,
RouterStation, RouterStation Pro
 StationBox 5 GHz 20 dBi SISO....
what reflector uses material?
I think the best is aluminum...!!!
i think same
for driven i think copper
