CIFRA-12 - external panel directional antenna
Universal remote panel antenna for receiving and amplifying digital TV (DVB-T, DVB-T2) and analogue (UHF) channels. Connector type is F-female.
Operating frequency range, MHz 470-790
Gain, dBi 10÷12
The width of the days in H-plane, degrees 37÷50
Days width in E-plane, degrees 62÷63
The sidelobe level, dB, not more -13
Input impedance, Ohm 75
SWR in the frequency range, not more 1.8
Polarization horizontal
Weight with mount, g 3770
Overall dimensions without mounting, m 0.33 x 0.59 x 0.11
Connector F-female
The emitter material, the coating
galvanized steel, plastic coating
Material of protective box
ABS-plastic with protection from ultraviolet radiation
Operating temperature range, gr. Celsius -40...+60
